Anyone having what looks like paint issues on the roof of their NX? Happened to notice today that there’s a brown spot (feel like rust?) as well as lots of white marks just in front of the sunroof. I tried cleaning it off with a bit of water but it’s not disappearing. Not feeling anything either so it seems like it’s under the clear coat
For reference, this is the NX450h+ that I got in May 2022
That doesn't look normal at all. I doubt it's bird droppings.
I'd try something more potent than water, starting from a simple wash, to bug and tar remover. If that doesn't work - I'd go to the dealer. Surface rust should not happen (and is covered under warranty) on new vehicles.
It's possible there was some contamination during the paint or clearcoat process - but that would still be covered.
Mystery solved and yes it was something dripping down on the car. The roof of the parking garage my wife parks at has rusted beams that drip onto the cars below when it's raining. We found similar stains on the second (older car) we have. She's no longer allowed to park this car in that garage
They were able to clean it and no spots afterwards?
No. I got side tracked with a death in the family and I didn't get a chance to get this cleaned up. Now that snow's here, I'm not sure i'm going to get a chance to get at it until spring
Sorry to hear about the family.
I would try to prioritize getting that cleaned up ASAP so you don't permanently damage the paint. With the right product it shouldn't take more than a few minutes
Agreed. I'm totally lost on the sea of products available and I'm partially afraid of causing more damage than good. Thankfully I have an older car I can test things out of if needed. Do you, or anyone, have any suggestions on what product to use?
just spot clean with soap and water and rinse (preferably car wash soap) if it's more stubborn, you can try a "clay kit" from any auto parts store. then put some wax on it to protect the area after you are done. any close up pics?
, which is designed specifically for vehicle paint so it shouldn't damage the clear coat at all. If there are calcium-like (white) deposits you can try white vinegar. Soak it into a paper towel and lay it on the spots to soften them.
I don't know for sure, but I think if it was my ~$60K almost brand new vehicle, I'd find a good detailer and take it to them for resolution.
You could potentially do more damage, especially if your not sure what to do or what products to use, and waiting will likely only make it worse, especially through winter if the rust has already grabbed hold.
If you're not afraid to get your hands dirty and put in some elbow grease, go DIY. There's a satisfaction you get from doing these kinds of things yourself.
The Iron remover quoted earlier works well as does white vinegar too. But I would do wash, then a clay bar, then a polish. If you had a ceramic coat or PPF installed earlier, it will certainly make the job infinitely easier to do.
