Rookie question, again. I’ve received the actual VIN from my dealership. All I received from them telling me that the vehicle changed to F status which I’m curious about the arrival date of the vehicle.
Can anyone check if you guys can see the arrival date of my NX350h?
Here's your window sticker, if it matters:
Says it was created 7/28/22, so if NTM is correct, you're getting your car 7 weeks after that. Must be exciting!
this helps a lot! Thank you for checking for me since I couldn’t find the actual window sticker. And yes, we’re excited!
if i remember correctly F status means it is in their lot and ready for inspection, wait about a day or 2 its ready for pick up
This is not correct. F is Freight meaning that it is essentially moving by train or boat, depending on where it was built. After F it goes to GT which stands for Ground Transportation which is indicative that the car will arrive at the dealer within the next 24-36 hours. Once it's on the dealer lot it transitions to G which stands for Ground.
That is great info, thanks for sharing. Anymore codes you can share?
