Ambient Illumination not working
8th Gear
Hi all,
In my NX 350h, the Ambient lighting in the "Illumination" setting has "Brightness" level set to 0 for "all zones" and for individual zones. I am unable to increase the brightness. It was working in the past and I do not know how it got disabled. Is there a way to enable?
I read something recently in the owners manual that if you turn your dashboard brightness to the lowest setting it affects your ambient lighting. You may want to check that.
8th Gear
Thanks @Dswhittle . After some trials, I figured it out. In the "lights" settings, you can configure the time period for the exterior and interior lights to glow after you exit the car. If you turn "off" the settings that tells how long the internal lights should glow when the door opens, the ambient illumination is disabled.
Hi all,
birdhunter
01-13-17 02:40 PM
