Hybrid Technology Unique topics related to the 2022 and up NX hybrid drivetrain and other features/options found only on the NX Hybrid models. Please use the main forum for discussion about shared components with other 2nd generation NX models.
350h puddle lights
Old 10-30-22, 06:29 PM
Lakerstrg
Lakerstrg's Avatar
Originally Posted by FWCA
My ultra luxury 350 doesn't have the puddle light either. The cover is a bit recessed. Does any know how to pry open it? I worry that it will drop inside the door panel. Did anyone install puddle light themselves?
yes I did. You just use a small flat head screw driver if you don’t have those plastic removing tools. Pry outwards from the side closer to the door hinge. It will come off towards you.
FWCA (10-30-22)
Old 11-01-22, 05:07 PM
gerardz
10th Gear
gerardz's Avatar
Default i checked again and there are no wires in the base model 350H in the US
Old 11-01-22, 05:21 PM
zanewyn
zanewyn's Avatar
Yea I just installed them on my 350h ultra luxury. Really easy to pop open if you have the plastic prying tool. I pryed from the bottom and it came out easily.
LStoneX (11-01-22)
Old 11-02-22, 08:32 AM
StraySheep
StraySheep's Avatar
Can someone confirm if I order the side puddle lamps from Lexus dealer, do I order quantity = 1 and it comes in a pair for both doors?
Or I need to order a quantity of 2, one for each door.
Thanks
Old 11-02-22, 08:46 AM
rsnaider
rsnaider's Avatar
Quantity of 1 and there are 2 lamps in the box.
Old 01-24-23, 03:45 PM
isaacsow
isaacsow's Avatar
I have a US base model NX 350h that was built in Canada. I don’t see any wires - definitely was not attached to the back of the cover. I pulled the whole bottom of the door panel and don’t see any wires. Has anyone confirmed if the base models in the U.S. have the wires in the door for the puddle lights?
Old 01-24-23, 04:16 PM
raviola4
raviola4's Avatar
Originally Posted by gerardz
I had read that somewhere before. I too have base. Not a big deal to me but would have been kinda cool to have added.
Old 01-24-23, 08:04 PM
Dino2K
Dino2K's Avatar
Hmm, very interesting that the US version are different than the Canadian version which doesn’t make any sense. Both my brother 350H Executive package and our 350H Ultra Luxury doesn’t have the puddle light but the harness is there behind the blank. One side the harness was plugged into the blank but the other side wasn’t and the harness was jammed between the door and the panel.
Old 01-25-23, 02:58 AM
Dunerking
Dunerking's Avatar
I have a set of OEM puddle lights from our ‘23 NX450H+ if anyone is interested.
Old 01-25-23, 04:13 AM
Freds430
Freds430's Avatar
Received 1,140 Likes on 739 Posts
Fifth vehicle with Lexus puddle lights. All the others bought on Amazon and yes a little less expensive but no where near the brightness and clarity of these. The light almost gives a 3d effect and are $46 a pair. The NX has no lights in the back doors. The rear trunk puddle light is a Lexus part. I ordered online at Lexus Charlotte. The NX comes with one LED bulb in the trunk hatch. As you can see in the pics the new one is four and so much brighter. Two mintues to replace. Just like the door lamps. Pop out the old one unplug and plug the new one in. It comes with an adhesive strip that you wrap around the connection. No instructions in the box.
https://www.addcarlights.com/product...hts-car-ghost/
Old 01-25-23, 03:23 PM
Gen2NX
Gen2NX's Avatar
Has anyone taken off the inter door panel to see if the wire was left zip tied to the wire harness somewhere in the door . This would be a great deterrent for many that would like to do this mod . But I would do it if someone could take a picture and show me the wire connector is truly there .
Old 01-25-23, 03:49 PM
RKF350
RKF350's Avatar
NX 350h base. Pulled the lower half off and look around and could not see any wiring tucked or taped anywhere.
So anyone knows if the wires are up higher it would be nice to know.
Old 01-26-23, 09:22 AM
IntrinoX
IntrinoX's Avatar
These are from LexusAcc.com
Love the 3D effect it gives out and definitely the clearest projection I've experienced!
Attached Thumbnails 350h puddle lights-img_8437.jpg   350h puddle lights-img_8438.jpg
The following 2 users liked this post by IntrinoX:
Freds430 (07-08-23), Kodiak412 (07-23-23)
Old 07-07-23, 11:07 PM
IS_NIICE
IS_NIICE's Avatar
The connector that plugs into the light that’s currently installed is the same that you would plug into the new light.
you guys can’t be serious?
Old 07-08-23, 04:36 AM
Freds430
Freds430's Avatar
I have these in our RX, NX and put them in a friend's NX. Have bought numerous other brands on Amazon cheaper price not anywhere near as bright and sharp. 75% less cost than OEM.
Quick Reply: 350h puddle lights
