Easy Access Seat Positioning
Is there some method of automating the seat position to its very lowest point on entry so that I don’t have to crane my head awkwardly to enter and exit? Right now the seat adjusts automatically to the correct driving position but doesn’t adjust to the lowest position on exit.
There is but it has to be set and enabled to move back on exit. HOWEVER, if your seat is fairly far back as a standard driving position, it will not move back. I am 6' 1' and I have the seat back fairly far, almost all the way. It does not move back unless I adjust the seat forward as my preferred driving position.
Make sure you have it enabled in the menu...customization...I think?
It has to be set for the exit position on the 3 buttons on the door. Not the 1 or 2 button, the other one.
I know my explanation sucks, sorry.
Thanks for the advice. I’ll see if I can implement this. Hope it works even if my driving position is not all the way back. I’m just trying to get seat to lower all the way down for exit and entry.
You should be able to do that. Just make sure you enable the feature to do this. I also had the steering wheel moving in and up out of the way.
Newnxer (10-30-22)
Hello, here we have 1 more solution to improve the driving position of your car
https://www.spacershop.com/en/produc...-wheel-spacer/
