2023 Illuminated Door Sills
5th Gear
Has anyone with a 2023 tried to install the OEM illuminated door sills?
I purchased the puddle lights and door sills to install myself. The puddle lights had a connector behind the blank and was a very easy install. When I took off the stock door sills, I could not find the connectors anywhere on either the left or right side doors.
I was under the impression that these were plug and play and wiring was ready. Has anyone else with a MY2023 NX350 tried to install these? If so, was there a connector under the stock sills? Does anybody have any pictures or any advice on where to look?
Thanks in advance.
Thanks in advance.
Stedman (07-01-23)
I can't answer directly; but, I can share my experience with another Toyota vehicle with a port installed option.
I received port installed bed lights in my Toyota truck. Having disassembled the interior, I can tell you that they added wiring specifically for these lights... all the way from the switch on the dash to the back of the bed. I suspect that could be the case here; it would at least go some way towards justifying the cost of these (though still multiples of the bed lights). I like the bed lights, they serve an important function; I feel that these sill lights only lighten up my wallet.
Good luck.
Good luck.
Here' the instructions from a 5th generation 2019-2022 Avalon, I'm betting it would be very similar.
Did this on Two CT200Hs and Two 2021 ES300hes. Use fingers, no tools required. except maybe to cut the zip ties Lexus provides after you are done.
@pcheezy3 On our '22 450h+ the plugs for the sills were actually up under that sorta triangle plastic trim piece towards the front of the car and NOT below the non-illuminated sill. I kinda panicked for a sec when I pulled the old ones off and didn't see any plugs... So pop that piece off as well (it's the next piece that the old sills connect to towards the front of the vehicle) and hopefully you'll see the plugs nicely tucked in there.
5th Gear
5th Gear
6th Gear
Could i trouble you to take a photo when you get the chance? Also, what variant of NX350 did you get? The hybrid or petrol?
They are pretty easy to install by yourself. There is no need to pay extra for the dealership to install it for you. Just study the attached installation instruction in advance and you can get this done in 20 mins.
SgtLip (06-28-23)
6th Gear
No idea why i cant find the connector even after opening the triangle piece. I'm in australia on f sport grade nx350 petrol version (made in japan). Guess i have to ask the dealer..
I installed mine a couple of weekends ago. It was easy to do. The hardest part was figuring out how to pop off the plastic piece under the console to get to the connector. Once done for the first side, the other side went quickly.
One thing, they don't stay on when the door is closed and they don't change colors with the ambient lighting. They are only illuminated when the door is open. Most may already know this, but I didn't so passing along for anyone who wasn't sure.
The following 3 users liked this post by Nightlight:
