Nx350 door handle button frozen
#67
so.. are we just locked out until the weather gets warm? Just have to manually melt it with our hands and ****? Lmao what the fack
#68
Is everyone experiencing this issue in cold climates? I took delivery back in Nov for a 2023 model and haven't encountered it at all. Located in Toronto
*Knocks on wood
*Knocks on wood
#69
If you do not experience this issue then consider yourself lucky, and your door handles were constructed properly. Lets hope you haven’t spoke too soon, as this weekend the temps are going to fall.
Good Luck, I hope your door handles are fine
#71
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/pxl_20230108_144539522_712c443c5416771a1c033da7ab0f99a51a036289.jpg)
zanewyn (01-13-23)
#72
It will melt with your warm fingers over the rubber pad (in the handle) after a few minutes. It's only my driver's side that freezes, I craw over from the passenger side. You can still open the door from the inside, so it's not a safety issue in case of an emergency.
#73
I’ve been following this thread for my 22’ NX350H and haven’t experience this issue yet. This morning it was cold and freezing ice, I tried opening all 4 doors and it does open but felt like it’s going rip the door panel off as I can see it’s moving in out and out when I try to pull it. Sigh, why did Lexus change this door handle design is beyond me and they should have stick with what have been working flawlessly for the last few generations!!
The following 2 users liked this post by Dino2K:
Randyp1234 (01-13-23),
weaver483 (01-02-24)
#74
#75
For the past few days, the place I lived dropped to below 0 degrees, and I parked the car outside. So this morning when I tried to open the driver's door, it appeared that the rubber button on the door handle is 'frozen', I can't press it and open my door, I checked the other doors, they all working fine, just the driver's side and I have to open it from inside by entering the passenger seat...(there's no ice around the door so the door itself is not frozen)
Has anyone experienced this issue before? is this something the dealer will fix/ replace?
What a bummer to discover in the snow.
