Nx350 door handle button frozen
#106
In 2003, dooring was the cause of 11.9% of all cycling injuries registered in Toronto, while 8% of all serious injuries of London cyclists were the result of a collision with a car door. Dooring claimed the same percentage of victims also in Victoria, Australia, between 2006 and 2010. According to experts, dooring injuries rank among the less dangerous ones compared to other kinds of accidents, but they shouldn’t be ignored. Dooring can kill too. In New York City, dooring accounted for the deaths of 7 (i.e. 3%) out of the 225 cyclists killed in total from 1996 to 2005. In London, dooring claimed the lives of 3 people between 2010 and 2012.
Preventing dooring is all about the inside door release, not the outside, so initially I could agree they should have just continued to use the touch sensor of the old handles Toyota and Lexus have used with the smart keys for many years, I think perhaps the issue is on those handles the touch sensors only unlock the door (does not release the latch, you need to mechanically pull them), Since they are subject to accidental triggering (as anyone who has ever washed their car with the keys in their pocket knows), I guess Lexus figures this new system requires a specific button push to unlock AND release the latch so your door doesn't open by itself (too often, anyway).
#108
Seriously, this is not a fix and is asking a lot for owners to do this. Thank goodness I don’t live in the cold climate.
I’m sure Lexus is working on a permanent solution but it just makes me think why didn’t they just use standard pull door handles on the outside like previous model and then incorporate the digital latch on the inside.
#109
This is hilarious, so the owner has to remove there glove, freeze there hand rubbing it back and forth in the freezing temps to warm the rubber pad? What about folks in Canada that have below zero temps for days and days on hand. I’m sure they’re going to love this idea.
#110
It would be nice if manufactures would solve the issue of people driving without their headlights on, and or indicating to the driver that lights are not on. But either the gauge cluster is always bright now, or the DRL are so bright people assume the headlights are on... I'd much rather see that implemented somewhere than electronic door handles. I don't think I've ever said "I wonder how I could open my door in a cooler way". Manual door handles have worked now for me and I've been driving for 26 years.
-Nigel
#111
Hello
A small update for those that have experienced the frozen door lock issue; I just picked my 2022 NX350h from the dealer today from its 24K service and the service manager mentioned that new door handles are now available to address the problem. He told me I am number 5 on his list of customers with the issue. He told me that the dealership had fixed their first NX about 10 days ago and that he was hopeful that the new handles have addressed the problem. We just had a rain/ice storm about 2 days ago and the customer that got the new handles had no issues. I, on the other hand, had 3 of my door handles completely frozen.
I would recommend any one that has had the issue of frozen door handles to reach out to their local Lexus dealership.
For reference I am in Halifax, Nova Scotia Canada.
I will post an update once the door handles are replaced.
Cheers
Toby Field
Cheers
Toby Field
#112
Hello
Cheers
Toby Field
Cheers
Toby Field
#113
Hello
Cheers
Toby Field
Cheers
Toby Field
#114
Hello
Cheers
Toby Field
Cheers
Toby Field
But last year I did not have this issue at all. And hopefully, solve this issue after replacing its door parts.
Also please share your replacement parts and working well or anything.
You're really helpful and thanks,
#115
Cheers
Toby
#116
I believe it is the entire handle assemble. The service manager said they had to order the correct colour for my car. He said it would take approx 30-45 min per door. I will post more information once I get my call to go in for the work. I will also see if I can get the part number.
Cheers
Toby
Cheers
Toby
However, how would you know if they’re not just installing the same part? Will you be able to tell the old part# from the new one they will be installing? Sometimes without an official TSB bulletin from Lexus they may just be replacing it with the same part.
#117
I am optimistic that this is a different part than the original door handle. I have been talking with the service manager for the past year about this and swapping the door handles for the same part was not a solution they wanted to do. He told me early in the spring that Lexus was working on a fix. I have no reason not to believe them.
I will ask when the work is done if he can get me the original part number and the new part number.
Happy Holidays
Toby
Happy Holidays
Toby
#118
I have the same problem. In order to enter the car I use the passenger door and open the driver's door from the inside. Went to the dealer and they seem to think that condensation if forming inside the door handle and freezes when it is below 0 Celsius. That's why you can't open the door. I also contacted Lexus and after provided the VIN I was told that there were no recall on my NX and to go to the dealer. Went back to the dealer and they told me that they have advised Lexus of the situation (many Lexus owners have this problem, one of them all 4 door would not open below freezing) and are waiting on Lexus to take action. You could always use the physical key that comes with the key fob. The only problem with that is that key is made for emergency use, it's so cheaply made along with the little cheap key hole cover that both would break in no time. It would seem that this problem has been around since the 2022 NX model... I guess Lexus are not in a hurry to deal with this situation, I also had other problems with the 2023 NX 350h. So much for reliability and Peace of Mind.
Droynick (12-24-23)
#119
I also called Lexus and the woman who answered the call just told me that there were no recalls on my vehicle and got to the dealer to get them to diagnose the problem. She was very rude and kept interrupting me. I go to the same dealer Belair Lexus in Ottawa. Funny enough the Service Rep was on the telephone when I arrived and they were discussing the exact same problem. I now keep track of the date and temperature and which door I cannot opened. It is very frustrating that a company like Lexus who are renowned for their reliability can't even seem to fix a problem like many of us are experiencing. This has been going on since the NX 2022 model, 2 years now.
#120
One would think Lexus would have tested this in the cold climates of Canada before they implemented this new door latch feature.
