Disable Start/Stop System
Does anyone know how to disable to the start/stop system on an NX350? The best solution is to have a menu choice to enable/disable the start/stop system, but the manual or some online searches show up negative.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Short answer: Unfortunately, it cannot be permanently disabled. (In my previous BMWs, the dreaded auto start/stop could be coded away.) In the NX350 turbo, however, you can shut it off after each time you turn on the engine.
The longer answer: https://www.clublexus.com/forums/nx-...t-disable.html
How do you turn it off after you turn the engine on? I only saw the setting for Standard or Extended under Setting >> Utility >> Start and Stop. If only they have and OFF option. Why Lexus, why?
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/1620x2000/d42b318c_5a49_451a_a21f_0fb122f465b8_0e4f96347f52858146c8e362a7148a0537b70497.jpeg)
Thanks for pointing out that button… start/stop really should be automatically disabled when you activate sports mode, surprised it’s not!
Bimmer32 (01-06-23)
Thanks, redhot47fl. I can't believe I didn't see that. I also found out that if you don't step on the brake hard at a stop, the start/stop feature will not engage. I kind of like that solution too. I guess I am use to the BMW with manually turning it off and staying it off unless I turn it back on.
As for not liking the feature, the NX 350 is not a hybrid, so every time the engine starts, it shakes the car a bit.
redhot47fl (01-06-23)
Alainis300
05-28-17 08:36 AM
