Side mirrors tilting downward
5th Gear
One of the things I noticed and liked on my new NX was that the side mirrors tilted downward when I put the car in reverse. They no longer do this and I have no idea what setting I could have changed to effect this. Any help?
Make sure your mirror select button (to adjust either the left or right mirror) is selected for either the left or right mirror. See if that helps. I remember from the manual it said that if neither button is selected (ie, neutral position) it disables the reverse tilt feature.
haven’t tried it exactly to verify, but let me know if it helps!
blueless (01-15-23)
My RX350 and NX350H does the exact same thing and it might need to be adjusted as it wasn’t set from factory. You must have your side mirror on either left or right when put it reverse and adjust your mirror to the desire down position for both left and right mirror. Once you do that the mirror will tilt down to the position that you have set it last, hope to at helps.
5th Gear
