Aftermarket Rim Specs
Looking up both AG and Forgiato I think the Forgiato Fliw series look great! Do you remember the offset? Is your setup staggered? I see your in California…are in So.Cal? If so where did you go to get the setup? Thanks
Dont remember offset, I did fitment myself, and yes its lowered on coils. I am in SocaL
We’re in Agua Dulce (north of (Santa Clarita)..were you happy with the rim/tire shop you went with? We live in the country-ish and a little concerned going with a tire with very small sidewalk…maybe 22” rims and a tire with a slightly taller sidewalk?
The stance looks great! Did you notice a big difference in ride going from the 22” to 24”? Do you remember how much it was lowered with the lowering springs?
the I ag wheels are 22s with high sidewall. Didnt like the look. Perhaps because I have always run stretch tires on the Ag’s. Had them on my 2015 GS and 19’ Es
no difference on ride from the OEM 20s to 22s to 24s.
Not sure how much it lowered but it did lower quite a bit from stock.
stock height
stock wheels lowered
22s lowered
and 24s
stock height
22s lowered
and 24s
stock height
22s lowered
and 24s
stock height
22s lowered
and 24s
yes, ag wheels are the brushed steel.
lowering kit I ordered from Japan Direct. Rsr.
as far as wheels I actually bought them online and just had a local shop mount. Much cheaper this way.
Thanks again. Is Japan Direct the vendor you bought the spring kit from? Also if you remember which online store you got the rims and tires that would be great!I may go with the Forgiato Flow 002 for a slightly different look. Thanks again!
