NX - 2nd Gen (2022-current)
NX OEM BBK Solution and other models too
Old 05-10-24 | 11:08 PM
  #61
Rarebird1's Avatar
Rarebird1
Originally Posted by Al575
I installed the RX500h calipers on my NX350h. Install was pretty straightforward.
Did the calipers fit on the og rotors or did you change everything? Anybody know if I can change just the calipers on the RX4?
Old 05-11-24 | 08:44 PM
  #62
IntrinoX's Avatar
IntrinoX
Have to change rotors too.
Old 05-11-24 | 09:20 PM
  #63
Rarebird1's Avatar
Rarebird1
What about the back? Are they the same brakes with different calipers or are the rotors different on those too?
Old 05-12-24 | 07:23 AM
  #64
midcow3's Avatar
midcow3
Thumbs up
Nice write-up. Do you notice a significant difference in better braking ?
YMMV,
MidCow3
Old 05-12-24 | 12:42 PM
  #65
IntrinoX's Avatar
IntrinoX
The rears are the same as these other models. It's only the front that you want to change.
Old 05-14-24 | 04:32 AM
  #66
NacsMXer's Avatar
NacsMXer
Anyone have weights of the rotor and calipers (with pads and fittings)?
Has anybody weighed the rotors and/or calipers vs. the stock NX equipment? I'm hoping that the OEM big brakes rotors would be at least equal since they have a 2 piece design with aluminum center.
Also how is the brake dust with these vs. stock?
Thanks!
Old 05-14-24 | 01:26 PM
  #67
5ive19's Avatar
5ive19
Thank you for sharing this write-up. I love OEM bolt-on upgrades! IMO, this is almost a direct bolt-on since you need to drill the knuckle to accommodate the bolt. Probably a dumb question. Can the knuckle be replaced with the one from the RX or is it totally different from the NX?
I also wonder how regen braking will work with this on the PHEVs.
Old 05-14-24 | 02:51 PM
  #68
IntrinoX's Avatar
IntrinoX
Works the same way. Had this on my RX450h.
Old 05-15-24 | 08:45 PM
  #69
Rarebird1's Avatar
Rarebird1
Do you have to drill into the knuckle only on the NX or is that go for all knuckles other then the 500h?
Old 05-17-24 | 11:23 AM
  #70
IntrinoX's Avatar
IntrinoX
RX knuckle is already large enough to accommodate the new caliper bolt, it's actually the same as our stock bolts.. This only applies to NX.
Old 05-23-24 | 08:42 PM
  #71
Rarebird1's Avatar
Rarebird1
Thanks for the answers man, I appreciate it. Do you know if this changes what wheel offset we should be using for the RX?
Old 05-24-24 | 05:05 AM
  #72
NacsMXer's Avatar
NacsMXer
Thanks!
Does anybody know the weight of the new 2 piece rotors vs. the originals? Rotational mass is an important factor to consider.
Old 09-04-24 | 01:15 PM
  #73
21ES350F's Avatar
21ES350F
3rd Gear
Originally Posted by 350phi
The front brakes are from a 2023 Lexus RX350 F Sport
I believe they have both unpainted and black painted versions. black painted version is from the 23 RX500h
They're just 6 pot Advics caliper with 400mm x 36mm two piece Advics rotors.
Will work on:
2010+ Lexus RX 350/450H/450HL
2015+ Lexus NX 250/250T/300/300H/350/350H
2010-2019 Toyota Highlander
2011-2020 Toyota Sienna
Direct bolt on to the front.
You will need:
Both front caliper
Both front rotors
Both front pads
pin kit for each caliper
brake lines from each caliper
OEM caliper bolts. they're m14x1.25x35mm bolts from lexus.
100% OEM and bolt on. will need a minimum of 20" wheels.
all part numbers should be below
edit: made some changes on the information.
Do you think this would work for 19-24 Lexus ES?
ericzuck
ES - 6th Gen (2013-2018)
07-18-22 10:20 PM
ncatona
05-21-21 09:58 AM
yyymmm31
01-06-21 07:02 PM
Mtandle
03-08-20 10:43 AM
shivam
05-17-13 07:28 AM
