NX - 1st Gen (2015-2021)
Removing Rear Trunk Panels
Old 02-10-17 | 10:08 AM
Age87's Avatar
Age87
Default Removing Rear Trunk Panels
Hey everyone,
I was trying to install an amp/sub in my car last night and got most of it done (that grommet through the firewall sucks by the way). The only part I couldn't figure out is how to remove the passenger side trunk panel (the side without the 12V) so I can tap the signal from the amp for the line out converter. I was able to remove the top area where the seatbelt goes and the grocery hook easily. I also was able to pop it out just a smidge but there was still a bit of resistance that I was uncomfortable just yanking on to rip everything out.
Anyone know how to or any tricks how to get it off? Or should I just run the line out converter from the rear of the headunit - i'd like to keep it localized would rather avoid opening up the dash as it looks fairly complicated.
Thanks in advance!
Old 02-10-17 | 11:25 PM
no1SomeGuy's Avatar
no1SomeGuy
This piece? Unfortunately you need to pull a bunch of stuff all around it to get it out...
Old 02-12-17 | 01:23 AM
Rozay604's Avatar
Rozay604
The grommet is easy and so is the panel on the side
Old 02-12-17 | 12:13 PM
d8168055's Avatar
d8168055
Hate to jack your thread, but what about the a-pillar housing, what do I need to remove to hide cables behind it? I'm worried about the cable getting in the way of the side airbags in the event that they get deployed. Thank you, all
Old 02-13-17 | 03:13 PM
Age87's Avatar
Age87
Thanks! Do you happen to have a key for what the numbers mean?
Old 02-13-17 | 07:09 PM
no1SomeGuy's Avatar
no1SomeGuy
*A
for Power Seat
*1
DECK TRIM SIDE PANEL ASSEMBLY RH
*2
INNER ROOF SIDE GARNISH ASSEMBLY RH
*3
LUGGAGE HOLD BELT STRIKER ASSEMBLY
*4
NO. 1 LUGGAGE COMPARTMENT TRIM HOOK
*5
NO. 2 BATTERY SERVICE COVER BOARD
*6
ROPE HOOK ASSEMBLY
*7
UPPER DECK TRIM SIDE BOARD RH
Age87 (02-14-17)
Old 02-21-17 | 11:06 AM
Age87's Avatar
Age87
After a very nerve racking removal of the panel and some drilling, soldering, etc...
Thanks for everyones help!
Old 02-21-17 | 11:09 AM
Age87's Avatar
Age87
Amp kill switch
Sub volume control next to the steering wheel.
You can sort of see the kill switch in relation to the sub.
sorry for the double post!
KenSavoy
10-16-19 04:56 AM
tither777
03-26-11 01:02 PM
KNKGS400
06-12-02 12:27 AM
Static911
08-04-01 11:23 PM
