Pacific For events in California, Idaho, Nevada, Oregon, Washington, Hawaii, and Alaska.
next meet!
Old 09-01-05, 01:32 PM
blk on blk
blk on blk's Avatar
Exclamation
Originally Posted by nismo013
Not sure if I can make it .. I'll be prepping my car for.... thumbup:
oh and I saw b13gripper again today ... that would be the 4th time now .. lol
Correct me if I am wrong..but is that just the front section of an SC????
Old 09-01-05, 01:54 PM
nismo013
nismo013's Avatar
Yeah it's the front clip of a soarer 1jz-gte which should be here weds or thursday..
Old 09-01-05, 02:42 PM
blk on blk
blk on blk's Avatar
Red face
I wish I knew what the hell you just said...but I am thinking that is a pretty desirable engine...right? I am learning slowly but surely
Old 09-01-05, 02:54 PM
nismo013
nismo013's Avatar
Wink
Thats the motor the SC300 came with in Japan..
1jz-gte factory specs-
Displacement : 2491cc
Type : Twin Turbo Inline 6 Cyl
Valvetrain : Belt driven DOHC, 4 valves per cylinder
Fuel System : TCCS EFI, Premium Unleaded
Ignition System : Direct fire ignition
Combustion Chambers : Pent Roof
Compression Ratio : 8.5:1
Bore x Stroke : 86 x 71.5
Peak Power : 280PS (206 kW) @ 6200rpm
Peak Torque : 37.0 kgm (268 lb ft, 363 Nm) @ 4800rpm
Fuel Consumption : 210 g / PS*h @ 2000 rpm
Dimensions (LxWxH) : 860 x 670 x 665 mm (MTM)
: 845 x 670 x 665 mm (ATM)
Weight (complete) : 217kg
Turbos : CT12A (2x)
Compressor wheel : 37/54mm
Turbine wheel : 52/42mm
Boost : 0.60-0.69kg/cm2 (8.5 - 9.8psi)
Fuel Injectors : 380cc/min high impedance
Intake cam timing (o-c) : 3° BTDC - 41° ABDC
Exhaust cam timing (o-c) : 46° BBDC - 2° ATDC
Camshaft duration : 224 (in) 228 (ex)
Valve clearance cold : 0.15-0.25mm (in) 0.25-0.35mm (ex)
Spark plug : ND PK20TR11 / NGK BRK6EKPB11
Plug gap : 1.1mm (limit 1.3mm)
Base Ignition timing : 8-12 BTDC (jumper TE1,E1)
Idle rpm : 600-700
Engine Oil : SAE 10W30, API SH
(taken from clubna-t.com)
Don't worry if you posted something about a GS I wouldn't know what the hell you we're talking about either.. lol
Old 09-01-05, 05:08 PM
TRD_Power
TRD_Power's Avatar
If I had an SC300 I'd want one we'll just leave it at that.
Old 09-01-05, 05:42 PM
audi2nr
audi2nr's Avatar
ooh a 1j in oregon? sweet! i just got my ic and im about to purchase a new exhaust manifold and some piping too.! i cant wait to be turbo.........
Old 09-02-05, 12:58 PM
NoS
NoS's Avatar
Which I could make the lexus turbo but I gave up on that idea. If I ever have turbo it will be from buying a car with turbo already in it and mostly something Nissian, Toyota, etc.
Old 09-06-05, 09:10 AM
blk on blk
blk on blk's Avatar
Exclamation Is this a go?
Hey guys...it's Tuesday and no 'official word' (or I missed it...that does happen!) Are we on for this??
Old 09-06-05, 10:41 AM
silkiechic
silkiechic's Avatar
I'll be in oregon this weekend so have fun guys My car is having a timing belt change and stuffs right now... hope she's going to be ok when they are done with her.
Old 09-06-05, 02:08 PM
NoS
NoS's Avatar
Yeah seems the 10th doesnt work for most people.... so maybe the 17th (following Saturday)?
Old 09-06-05, 05:21 PM
audi2nr
audi2nr's Avatar
im down for the 17th !
Old 09-06-05, 08:07 PM
blk on blk
blk on blk's Avatar
Default 17th
I should be able to make it then...
Old 09-06-05, 08:52 PM
TRD_Power
TRD_Power's Avatar
cant make the 10th
Old 09-06-05, 10:39 PM
blk on blk
blk on blk's Avatar
Originally Posted by TRD_Power
cant make the 10th
What about the 17th?
Old 09-06-05, 11:31 PM
TRD_Power
TRD_Power's Avatar
unless it goes on till after 4 I can only go on mon and tues.... damn my job...
Quick Reply: next meet!
