Pacific For events in California, Idaho, Nevada, Oregon, Washington, Hawaii, and Alaska.
The Unofficial WA BS thread
Old 03-15-10, 04:38 PM
  #811
shonn
shonn's Avatar
hmmm roadtrip. Good idea sir.
Old 03-15-10, 06:37 PM
  #812
LazyAccent
LazyAccent's Avatar
Originally Posted by shonn
Hey Jones, haven't you gone to point defiance zoo & (aquarium)? But as far as the seattle one goes, eh it's alright. The remodeled some of it since i've been there. It is small, but still pretty cool. If you haven't gone yet, i'd just go to say that you've gone. lol.
I've been there WAY TOO much haha. Eh maybe ill go to the aquarium sometime. What about woodland park zoo? I havent been to that one either.
Old 03-16-10, 04:36 PM
  #813
IS3_FTW
IS3_FTW's Avatar
I went there for the first time this past January. Its a big zoo with all kinds of animals.
No aquarium at that zoo tho. Well at least none that I saw. But of course the park is huge and would need a good 2-3hrs to walk around the whole park
Old 03-17-10, 12:15 AM
  #814
LEXveryG8
LEXveryG8's Avatar
Oh nice, zoooo, reminds me back in SoCal at San Diego Zoo. lol...good times
I'm going to have to visit the zoos around here, sounds like it's worth the walk?
Old 03-17-10, 07:08 AM
  #815
sway162
sway162's Avatar
Screw the zoo jk....Northwest Trek fellas!
The Honolulu Zoo was coo when I was there back in the day! haha
Old 03-17-10, 08:48 AM
  #816
LazyAccent
LazyAccent's Avatar
Im tired of northwest trek lol. I used to get in for free cause my friend worked there.
Old 03-17-10, 09:45 AM
  #817
sway162
sway162's Avatar
Fine! lol....
Old 03-17-10, 09:47 AM
  #818
sway162
sway162's Avatar
You guys heard of this issue or know anyone that experienced this? This was posted on my.is
Issue with spacers is when you buy cheap ones they expand and contract with heat (remember these are against your hub/disk) and so they create a gap that allows the nuts to be loose and wind off.
Happend to a local skyline here. wheel came off and killed a pedestrian.
Old 03-17-10, 12:45 PM
  #819
sway162
sway162's Avatar
After more researching...I heard that's a problem with using cheapo spacers over 15mm.
I feel better now. =)
Old 03-17-10, 01:11 PM
  #820
S30ZG
S30ZG's Avatar
I have some 30mms that aren't brand name spacers. I'll be sure to document whether or not the lug nuts become loose over time. Torqued them to 100 lbs so i think they won't be a problem.
Old 03-17-10, 01:32 PM
  #821
drksyde
drksyde's Avatar
I highly recommend that you get spacers that have hub centric rings... or else it will cause vibrations and other unneeded damages just because you wanted the space out the wheels closer to the fenders (which I think would be a dumb reason to cause damages) lol I am not sure how many mms you need til you need extended studs but I have 15mm H&R spacers and they come with extended studs
Old 03-17-10, 02:24 PM
  #822
IS3_FTW
IS3_FTW's Avatar
I, myself wouldnt go over 5mm spacers without extended studs. But thats me, and you can do what ever you like. Especially torque it at 100lbs lol
Old 03-17-10, 03:03 PM
  #823
drksyde
drksyde's Avatar
I wouldn't over torque beyond what manufacture recommends... there is a reason why there is a recommended torque load... too much will cause the stud to break... im sure all you guys have over torque something before and it broke right off and leaves you in a bigger mess. thats just my .02 cents
Old 03-17-10, 03:04 PM
  #824
sway162
sway162's Avatar
Yup, everywhere I read said to get extended studs anything over 5mm. I have Ichiba extended studs on it's way to me. =)
Has for hubcentric rings...I'm hearing that they are overrated and only really necessary for anything over 15mm.....This is from my research so far though.
Old 03-17-10, 05:00 PM
  #825
drksyde
drksyde's Avatar
without the hub centric ring, the wheel may not be aligned correctly making it spin unevenly causing vibrations when you drive. That is true that some cars do not require hub centric rings but my car (IS300) has a hub centric ring stock so I would think it is there for a reason. Otherwise, why would our cars come with the hub centric rings in the first place?
If you get a thin spacer, it is thin enough that the stock hub centric ring is still being used. Be very careful when using the "cheap spacers" because I have gotten some before in the past and they were unevenly machined causing vibrations. The vibrations can cause damage to wheel bearings (trust me, its not cheap to replace) and sometimes if your wheel is spinning unevenly due to uneven machined spacers and POSSIBLY from not having the hub centric ring... your wheel studs will break... I know because I have already been there and done that.
Quick Reply: The Unofficial WA BS thread
