Pacific For events in California, Idaho, Nevada, Oregon, Washington, Hawaii, and Alaska.
PNW pic thread (picz only)
Old 03-22-10, 05:05 PM
  #151
Overdose20
Overdose20's Avatar
Its on pump 92 gas and it just got tune by English Racing. I got all the bolts and 255 fuel pump.
Old 03-22-10, 08:57 PM
  #152
LEXveryG8
LEXveryG8's Avatar
Sorry this may be a dumb question, but what's a 255 fuel pump?
Old 03-22-10, 09:01 PM
  #153
Overdose20
Overdose20's Avatar
its just an aftermarket fuel pump
Old 03-22-10, 09:07 PM
  #154
LEXveryG8
LEXveryG8's Avatar
Thanks, now I see. Does it give racing fuel or something like that?
Old 03-23-10, 08:21 PM
  #155
kevin.tran
kevin.tran's Avatar
From my understanding (I'm not a mechanic so someone jump in if I am wrong) but an aftermarket fuel pump will push more fuel or the amount of fuel from the gas tank to the injectors. So that way your car won't lean out if your boosting at a higher PSI. Because if your leaning out too much you might make the HP you want or up to but your engine will deteriorate quicker due to knocking and so forth. That is why most time when people go turbo/supercharging they upgrade their fuel rails/pump/injectors. Also with an aftermarket Fuel Filter you might need larger injectors but depending on what the stock sizes are and how much they can handle sometimes you can get away with it. More fuel + more air = more power/hq/torque. Hope that helps Yogi! whew my brain hurts
Old 03-23-10, 08:47 PM
  #156
Overdose20
Overdose20's Avatar
That's right Kevin. That is a perfect way to explain it.
Old 03-23-10, 09:29 PM
  #157
S30ZG
S30ZG's Avatar
the 255 stands for 255 liters per hour that the pump can move. Its common to upgrade your fuel pump after a engine swap (think SR20 swap) because the stock pump doesn't move as much fuel as a 255 lph pump would. Its not an absolutely necessary upgrade for some engine setups if you are keeping everything stock, but after if you were to go from a 370cc injector to a 550cc injector it wouldn't work very well at all.
Old 03-23-10, 09:35 PM
  #158
S30ZG
S30ZG's Avatar
Originally Posted by benr33tz
You can just about almost hit 29 psi on stock internals with a good tune for evo's and that's probably on pump
oh idk that. all i knew is that the 4g63 can take some punishment but didn't know it could hold together with that kinda boost. How much psi can the stock snail run for prolonged periods of time?
Old 03-23-10, 10:26 PM
  #159
LEXveryG8
LEXveryG8's Avatar
Oh I see now, thanks guys for explaining things in detail to a NOOB!
Old 03-24-10, 04:47 PM
  #160
benr33tz
benr33tz's Avatar
The evo's 16g "evoIII +" has been known and track proven to hold 30psi solid. But that is maxing it out. So thats why its safer to keep it more around 24-28psi
Old 04-06-10, 01:40 PM
  #161
mixtnutz
mixtnutz's Avatar
How did I just see this thread now. That's what I get for not visiting this site regularly. Here is my standard pic whoring lineup.
Old 04-06-10, 02:15 PM
  #162
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
I don't know why not more Canadians put their pics here, we are technically pacific northwest. thsi thread is great.
Old 04-06-10, 06:00 PM
  #163
mkiiisupra
mkiiisupra's Avatar
New coilovers (going lower in the front this weekend), Aristo bumper, HID's 6k low/3k fogs, SPC adjustable upper control arms (camber corrected), Katzkin leather
new height
Old 04-06-10, 09:58 PM
  #164
Zoolander
Zoolander's Avatar
I'll contribute mine. Still pretty stock other than the 18's it came with and a mild drop but hopefully that will change a bit as time goes.
Old 05-08-13, 02:12 PM
  #165
sway162
sway162's Avatar
Three year bump! We need some activity......
Quick Reply: PNW pic thread (picz only)
