Alignment Recommendation in Seattle/Bellevue Area
Hi guys,
It's time for me to replace all 4 tires that has severe camber wears and would like your opinion/recommendation for a good/reputable shop who can handle 20 inch rims. I am hoping that the shop also has some experience align cars with OEM air suspensions.
Shop Name?
Location?
Price?
Thanks for your help!
Shop Name?
Location?
Price?
Hi guys,
Shop Name?
Location?
Price?
Shop Name?
Location?
Price?
Hi guys,
Shop Name?
Location?
Price?
Shop Name?
Location?
Price?
But Im on aftermarket AIR SUS
Speedware is a great shop. They have a whole bunch of race cars. check them out. Bel-kirk body shops has a suspension shop called Clarks and they're really good. My allignments been dead on for over 6 months now and when I was taking it to firestone, it'd be WAY OFF every month
les schwab is $60. But if you have air sus like air bags or air struts your camber changes every time you raise and lower your car. set a daily ride height and have them set it to that. other than that toe in or out is what can be adjusted, caster usually not adjustable unless you have pillow tops that are two-way (camber and caster)adjustable
Thanks everyone for your input!!!
I'll be contacting few of the shops including what you have suggested and go from there. I'll be getting alignment done next week along with getting the new set of tires mounted before the BBQ.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
Can you give me a name and number of the place you went, and how was the service?
Since I work in downtown Seattle, I decided to try out the Tru Line so that I could drop my car off in the morning and go to work while the car is getting serviced.
I had 4 brand new tires mounted/balanced ($29.95/tire I recall). Since I won't be driving aggressively with my LS, I asked them to not have much camber to reduce the inner tire wear. Turns out, when you fill our their sign in form, there are areas to select your typical driving style, give your weight etc, to get the true alignment values.
Alignment was (i recall) $149ish (sorry, don't have the receipt with me). Of course, there are tax, shop fees, tire disposal fees in my case added to the bill.
Overall, I am very happy with result, customer service, and after care. Only negative was the work was completed 40min after I went there to pick up. But they did not cut corners for sure. Owner explained all before and after alignment values, etc.. in detail, which I thought a nice touch. (If he was in a rush, he could've chosen not do so as the shop's biz hours has already passed by an hour.)I was told to bring in cars after (i forgot how many miles...got check my receipt) xxx miles to the shop so that they can inspect tire wear and adjust at no cost if necessary. Oh, I did not get any scratches on my rims from tire dismount & mount/balance
I did find some other shop less expensive but this shop was very conveniently located to suit my busy weekday schedule. Ferrari of Seattle sends their cars to this shop, as well (=they will be careful with your new expensive rims)
Here is the info.
Tru-Line Seattle, Inc.
312 Boren Ave S
Seattle, WA 98144
(206) 325-3340
http://www.trulineseattle.com/
Funny, I just found out there was one in Bellevue by my work, just happen to go down a side street and looked over and saw their sign Tru-Line Bellevue
I may have to bring mine there as its starting to pull a little to the right after I had one new tire replacement.
Thanks Nao! I found a place in Kirkland that costs $89 +tax. So it sounds like what you paid, is about right. Its called Clarks wheel alignment.
I will check tru line out, after I go through this shop. But I will call tru line, to see if they have any openings for tomorrow. I need it done ASAP![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thats why its best to buy in pairs
Thats why its best to buy in pairs![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
