Tire stretching
#46
Nankangs stretch really good and are cheap. I'm happy with the 225/35 on a 10. Dont have any pictures but the lip is fully exposed. Only drawback to a severe stretch on a DD is that i have to run 45-50 psi in the tires to keep them beaded. That with old single tap JIC SF1s makes for a harsh ride.
You need to keep higher PSI in (no more than 40) to be safe in case of leaks. If they leak anywhere and the tires goes down optimal PSI (32) then you're going to bend or crack a wheel in the smallest bump because there is nothing to cushion the impact.
I've stretched a lot of set up and never once put more than 38psi in my wheels.
