SC400 Idles Low When Warm
8th Gear
Hi, I own a 1998 SC400 (1UZ VVTI) when the engine is cold it idles fine at around 500rpms, when it's warm the car stalls unless I turn the A/C on setting the idle to 250rpms.
Parts I have replaced
- Replaced all capacitors in ECU
- Replaced MAF sensor
- Replaced Coolant temp sensor
- Replaced both VVTI solenoids
I'm not sure about the vvti, assuming it's no longer distributor and wires and has gone ignition coils. I would say IACV may need to be cleaned. Apples to oranges, but my 02 Celica had similar issues where it would drop the idle, or even stall. Once I cleaned it out it was good to go.
I'd definitely inspect your IACV like Tallyhoe stated to see if it needs cleaned. Did you replace your MAF with a factory part or an aftermarket unit? These cars really hate aftermarket MAF sensors...
8th Gear
The only thing non-factory is the MAF sensor, ill definitely change that. Also, the 1UZ VVTI doesn't have an IACV.
It's called ISC or Idle Speed control part number 22270-50020. You may need a gasket for this, so buy that first, and then proceed with IACV cleaner and a q-tip.
^^ Thank you for that correction! And good call on swapping out the MAF. That alone may correct your issue.
8th Gear
Alright while I wait for the OEM MAF sensor to arrive, yall got me scratching my head about the ISC I don't see it anywhere on the 1uz I swear the VVTI version doesn't have it unless I'm blind.
RudysSC (04-06-23)
