1uz right bank dead
5th Gear
Hi guys I have a 91 sc400 with a dead right bank, it has new plugs, compression 160+ fuel to the fuel rail, spark seem fine. It seems to run the same with or without the maf connected, iac valve is open but stalls if I block it off, have done a resistance test on maf which gives 4ohm at 13 degree.
Anyone have any advice? Thanks
Besides dead, maybe I'm a little thick, but is it a misfire? Assuming the assembly is rotating as you're able to get compression out of Bank 2. Or are these Bank 1 numbers? Are there any other maintenance issues with it? Just trying to get a base explanation on what it going on, for somebody to better assist you.
Have you pulled a plug and verified spark? It could be a dead ignition coil to that bank or an issue with the distributor for that side... That's about the only thing I can think of for why you'd be down an entire bank but maybe someone else will have another idea?
5th Gear
5th Gear
Well yeah I thought something like that but since each coil feeds 2 cylinders on each bank I figured the coils must be ok and I have moved leads around are they make no difference cheers.
Head scratcher here. Have you tried swapping ignitors to see if it switches sides? At this point wouldn't hurt to try to see if it's mechanical. If it isn't, maybe it's time to dig into the wiring aspect of it and ensure there is no damage in other pertinent sensors to the ECU. Maybe a damaged ECU, but i would assume the symptoms would be more randomized to both sides.
5th Gear
Thanks for the extra info... Definitely an odd one here. I think swapping ignitors is a good idea to make sure it's not something bizarre going on. Otherwise, if the ECU refresh is new and the issue came up after it may be worth sending back to make sure something didn't get soldered somewhere it shouldn't have...
