Car is getting way too much fuel. I'm stumped
Old 11-27-03, 08:20 PM
fc3s7
fc3s7's Avatar
First thing I would check is the injector wiring - ECU's fire the injector by pulsing to ground, and it sounds like youv'e got a short to ground for that injector. If that's the case, the #5 injector would be FULL OPEN all the time - definitely running the car rich .
Modern ECU's are typically REALLY hardy - I would moreso suspect the wiring or the injector.
Dale
Old 11-27-03, 09:18 PM
Supra4100
Supra4100's Avatar
I wondered about the whole short in the wiring bit. But after careful inspection of the bit I could trace down. I have a hard time believing the insulation of the wire would just deteriorate away. Following that specific wire It has been untouched. I also checked the pulses with a noid light. It blinks rapidly, but tends to have short wide open bursts of light. where the other 5 injector leads blink rapidly as they were supposed to. One last thing I wondered if it were a leaking injector, so i swapped with number 1 and it works fine for that cylinder.
Old 06-14-04, 01:32 AM
sc3boost
sc3boost's Avatar
Default anyone here
hey i know this is an old thread but did you geys ever figure out what the problem was, i have the exact same problem. 92 sc300 5spd, and for the love of god i cannot figure it out. for this reason i'm always in a bad mood, so before i start a new thread i just wanted to know if you guys figured this one out
Old 09-20-18, 04:51 PM
Nateboii24
Nateboii24's Avatar
Default Ecu
It is the ECU. No body updated it but there are lots of threads on this subject
Old 09-20-18, 10:18 PM
Supra4100
Supra4100's Avatar
wow! Talk about blast from the past! Made this post 15 years ago! Yeah the #5 injector pulse stayed constant.. replaced the ecu & she was 100%
smutts
01-30-19 10:09 PM
ALISC400
07-04-18 11:31 PM
AHJ
11-18-08 05:16 PM
MT Photo
01-04-08 02:34 PM
Supra4100
08-31-03 07:03 AM
Quick Reply: Car is getting way too much fuel. I'm stumped
