1jz to cd009 sc400
10th Gear
So i’m swapping a 1jz into my sc and pairing it with a cd009, the adapter kit i’m using is a pmc motorsport stage two adapter 250mm/9.84”. does anyone with the same setup have any suggestions for what driveshaft I can run?
10th Gear
10th Gear
well so far the engine with tax was around 4700, and for the trans alone i’m getting a cd00a (just a better version of a cd009) which should be around 6,000 with the adapter clutch kit shifter lines and pedals all together. you can definitely get the trans for cheaper at a junkyard if you find a 350z or something.
