HELPP MEE PLSS!!! struggle to turn on in the morings
1st Gear
So i bought a sc400 a few months ago and the first day i bought it it had problems it ended up being the ECU so i sent it to go get replaced after that it was running perfect then a couple months later my car would crank and struggle to turn on especially in the mornings or in the cold so i replaced fuel filter and fuel pump and its still just cranking foreveer to start im jus lost and wanna know what it is before i throw this car away lol please let me know anything helps
I would first try to give it some a little puch ofthegas pedal to see if it needs more air if it works your Idle control valve may be sticky. if it doesnt help do the fuel pump ECU 12v mod...search it in the forums.and check to see if the coolant injector switch located underneath the top coil pack is plugged in and or has bad wiring. also check that the serpentine belt isnt cutting the cam sensor wires.
lexdud
Performance & Maintenance
03-27-12 05:40 PM
