Need torques specs for 2jzge non-vvti
I am looking for the full intake manifold,fuel rail, and fuel delivery pipe torque specs. Also, should I replace those crush washers on the fuel delivery pipes? If so, what is the part number
Replace all gaskets and washers.
Sorry I don't know the part numbers to the stuff you need.
All the intake manifold bolts and nuts from the throttlebody all the way to the head are 20ft.lbs
The vacuum chamber that sits under the IM is 20 ft.lbs
The 2 metal brackets that connect the IM to the head are 13 ft.lbs
The big metal supports that connect the IM to the block and the PS pump are 29 ft.lbs
The reinforcement bracket that holds the TB to the head above the exhaust manifold is 15 ft.lbs
Fuel rail to manifold 15 ft.lbs
FPR to fuel return hose union bolt 20 ft.lbs
Fuel inlet pipe union bolt 30 ft.lbs
I got those numbers from my 97 service manual
1997Soarer (02-21-24)
Arcturus
07-27-18 06:48 PM
lexbubba90
12
08-22-14 04:27 PM
