Crazy missfiring please help!!!
So I recently had a faulty starter on my car causing it to click once instead of turning over. Once I put everything back together I go to start it and it doesn’t start I then unplug the MAF and it then starts but was miss firing I then replaced the injectors same problem the brakes are also hard to push even while the car is running I double checked the vacuums I didn’t see anything suspicious. I also used my 0bd1 scanner and pulled code 24(air flow meter) but that has always been there unless it finally took a ****** on me the car basically had a full tune up including fuel pump and filter and is my daily driver any help is appreciated!
Ok so you don't really know what is going on.
Sounds like you are better off making a post on facebook in one of the SC3/400 groups and posting a video. You will need to make a description for the post, detailed, otherwise the FB algorhythm won't let people see the post in their timelines
