1993 Factory Manual W58 to T56
10th Gear
Just a question if anyone has a write up or video on swapping out a factory manual W58 SC300. I'm ordering one from Grannas Racing and I'm kind of confused about the index plate and specifically the wiring. I get the feeling the wiring is different on manual SCs vs automatic SCs. I'm new to this forum but my Google searches keeps pointing me to auto to manual swap on SCs, Supras, and IS.
The only two things I can think of wiring-wise would be the reverse light wiring and the speedometer wiring. I'm not sure how you want to do the speedometer wiring, but a lot of people use a gps speedometer for these types of swaps. The two reverse wires should be pretty easy to spot and complete a loop to trigger the reverse lights.
10th Gear
I have had two of the Grannas Racing kits (but on IS300s). There is a conversion harness supplied that allows you to use Bluetooth to calibrate your speedometer. It's actually pretty trick as you can account for gearing changes and tire size changes. I assume the same type of harness is used for the SC, but am not 100% sure.
Oconee1985
SC- 1st Gen (1992-2000)
17
05-11-13 09:41 PM
