Sc300 Cranks but does not start
9th Gear
My 96 Sc300 is not starting and im getting confused. The fuel pump is working I can hear it prime and made the mistake of unbolting the fuel line. I definitely have fuel lol. I put in new plugs, wires, alternator, and the distributor i pulled off a running sc. What else do i need to check? Also my crank sensor is plugged in and it shouldn't be my ecu
It seems like you have probably left something unplugged while doing your tune up. Check and make sure the MAF sensor is plugged in, check all the plugs, make sure they're all plugged in tight. Make sure the security light isn't flashing on the dash while you are cranking it over. It's got to be related to the tune up. Keep this updated, I am sure you will have a solution soon
9th Gear
I see, that can definitely change your possible culprits. You just need to figure out if it’s a lack of fuel or lack of spark issue and then chase down where things are failing. So u can use some starter fluid to confirm that you have spark and not fuel. Just give a good blast down the intake tube, and see if it begins to start? Or sometimes you can a vehicle to start and idle momentarily with starter fluid. If it doesn’t change anything then your problem is a lack of spark. Once you have determined that, then it becomes a little easier to isolate the issue. If it’s a lack of fuel, you’ll just need to start at the fuel pump and make it’s coming on, and how far the fuel is going before it is getting interrupted? Or if it’s a lack of spark, then same thing, you’ll need to make sure the igniter is getting power and a signal etc, and then chasing it down from there
