NA-T, car, limited slip? or no....?
How many of you guys out there run with a limited slip? either the TRD or the rear pumpkin from the auto TT supra....
If I go na-t, will the limited slip help all that much?
I'm not roadracing it every weekend, so will it even matter much with day to day driving (will it help much in the rain and snow?) and some spirited weekend driving?
thanks
Ken
thanks
Ken
I do have the TRD unit. Its not installed yet. I am trying to gather all the info that I can because I may attempt this myself. If anyone has any useful information on this change...please share or point me in the right direction.
My reason for getting an LSD is the lack of traction. Its freaky when your rearend breaks loose at 45-50mph. This and some new 275 rubber in the rear should help.
Ken...I cant see why it wouldnt help in the rain or snow. (I really dont drive in either)
gadgetSC-t
gadgetSC-t
I have had two different LSDs in the car. Supra TT Auto and Supra NA Auto. They do make a difference. It depends on what you want. The Supra Auto TT LSD is the same ratio as the TRD, 3.769.
Your gains depend on your gear ratio. On a SC300 with a 3.769 gear you will lose alot of torque compared to the stock ratio, 4.27. But what you loose in torque you gain in top speed. The 3.769 will cause your speedometer to be off by a good amount (higher). Using the Supra TT Manual LSD exaggerates this torque, top speed ratio since it is 3.133. If you want an accurate speedometer and maximum torque use the Supra NA LSD which is very rare. If you want higher speed but not as much torque then choose a different gear. Just be careful with gears since you don't want the engine to be in a bad powerband for your regular cruising speed or daily driving.
I have the TT auto diff in my car... but my car still breaks loose at ~60mph ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
DaveH
DaveH
gadgetSC-t
gadgetSC-t
Just FYI, if you have a NA auto the speedo gear from the TT auto drops right in and corrects the speedometer.
DaveH
DaveH
There are 2 speed sensors, one is a *hall sensor* type, and the other has a gear on it. I can't remember which one is front/rear. Anyway, you remove the gear type sensor from the trans, slip off the NA gear (little white plastic gear) and slip on the TT auto speedo gear and put the sensor back into the car. I think the gear was ~$20. Well worth it to have your speedo read correctly again.
I never found a fix for getting the 5-speed to have correct speedo readings with the different differential.
DaveH
DaveH
Hey Dave,
How would one drop this gear in?
- Mike
Hey Dave,
- Mike
AutoCoutureSC
SC400 / 300 Classifieds
11-15-08 11:06 AM
