anyone got pics of their FMIC setup on a sc300
Old 01-11-04 | 12:31 AM
kmn5's Avatar
kmn5
just curious, what needed to be done on that particular down pipe??
I have the down pipe and mid pipe from the toyomoto kit. (have the toyomoto log style manifold and to4)
Haven't installed anythign yet, just wondering what roadbloacks I might come across
Thanks
Ken
Old 01-11-04 | 02:45 AM
aliga's Avatar
aliga
Former Sponsor
the dp and mp you have is it from a lexus? if so you should not have any issues.
I think gadgetsc's dp/mp was for a supra setup, which wont lineup with the sc exhaust most likely due to shortness.
Ed: correct me if im wrong. thanks..
Old 01-11-04 | 07:29 AM
gadgetSC's Avatar
gadgetSC
Gazi, your exactly right.
I used a supra dp that replaced my catalytic converter. I had to cut it short to mate up to the SP setup. The supra dp was too long and had a 3 bolt flange. I cut the dp to the length that I wanted and found this shop that had the 3", 2 bolt flange that I needed welded to mate up to the 3" 2 bolt flange on me SP setup.
Hope this helps.
gadgetSC-t
Old 01-11-04 | 08:37 AM
motorheaddown's Avatar
motorheaddown
...Scott....why the switch to bar-and-plate?...
There are many reasons. The April 2003 issue of Turbo Magazine has a great article that describes the pros and cons of tube-and-fin versus bar-and-plate. I tried finding the article at turbomagazine.com, but it's not in their archives.
In my case, bar-and-plate is a better choice. It'll sustain higher boost levels and more importantly has less pressure drop. Tube-and-fin, however, is more efficient.
We give up enough pressure due to 2.5" IC piping for a FMIC; no need to contribute more to pressure drop due to a tube-and-fin core. And efficiency isn't as important as pressure drop because I'm going to be injecting a meth/water mix just prior to the TB to make up for efficiency.
One way to make up for all the piping is to use a top-to-bottom IC with inlet/outlets on the passenger side of the car. That would elimiate a lot of the plumbing. I honestly feel the spearco IC made for the mkiii is the perfect choice for our car: http://www.suprasport.com/suprasport...es/spearco.jpg Plus, I believe it's bar-and-plate; so, it's smaller size compared to other front mounts isn't an issue in terms of flow. However, it's probably not the "popular" (i.e. "cool looking") choice. Had I known this IC was out there, I would have used it.
I finally have all the components to turn some big numbers (manifold, driveline/clutch, IC, fuel, EMS, and ignition). A stout IC was the piece I was missing. Unfortunately, I'm starting from scratch rebuilding the car; so, it'll take some time to produce the numbers.
-scott
Old 01-11-04 | 04:19 PM
Lex Luthor's Avatar
Lex Luthor
Got it if you need it bro, could scan it in.
Attached Thumbnails anyone got pics of their FMIC setup on a sc300-fmic-piping-3.jpg
Old 01-11-04 | 04:34 PM
motorheaddown
Thanks Jon... I have the issue; I was hoping TM had it on their web site.
-scott
Old 01-11-04 | 09:43 PM
TrboDANDEE's Avatar
TrboDANDEE
looking good guys. can yall post more pics with the bumper on? prefferably with the 97+ bumpers...
Old 01-12-04 | 09:28 AM
Lex Luthor's Avatar
Lex Luthor
Here ya go...
Attached Thumbnails anyone got pics of their FMIC setup on a sc300-fmic-bumper-on.jpg
Old 01-20-04 | 01:32 AM
lexus_sc400_n20's Avatar
lexus_sc400_n20
Here are some pictures installing the FMIC and a finished product. Note, the pic with the pipes is before it was finished being welded up.....
DT2k
SC- 1st Gen (1992-2000)
20
04-18-10 08:14 PM
ClubSupra
11-10-09 02:57 AM
USAF_RT
07-29-07 07:35 PM
zegnaguy
07-15-06 01:03 AM
dejacky
04-22-06 12:42 AM
Quick Reply: anyone got pics of their FMIC setup on a sc300
