View Poll Results: Best setup for turbo SC400?
Tiny twins for instant spool but not as thermally efficient
3.45%
Small single for great spool and somewhat thermally efficient
6.03%
Medium twins for good spool, better thermal efficiency, but high cost
43
37.07%
Medium single with good spool and very efficient
62
53.45%
Voters: 116. You may not vote on this poll
Best turbo(s) for the SC400? Vote!!!
Old 06-11-05, 07:27 PM
  #61
SC400TT
SC400TT's Avatar
Originally Posted by YZFR1
I have a set of HKS 3037's that i will someday put in the SC400.......... Wonder if there is any way to get a decent set of manifolds? Wonder if Weapon R could send me a kit
Dan
Nobody makes a set of manifolds for the SC400...Nobody...You will have to custom One-Off the project. Mine will be done soon, and you will see the pics.
Just for example, on a TT V8 set up, you will have to design and fabricate the driver's side manifold so that each of the four runners angles up so that the manifold will flow over the AC compressor high enough to allow the down pipe to flow back under the manifold, over the compressor, and between the engine and the frame rail. You cannot run the down pipe under the K-Member, as you would crush the Dp as soon as you drive over your first speed bump, or just rip it off...
On the passenger side, you will need to place the turbo lower so that the intake pipe returning from the FMIC will clear the turbo. It's alot of work, but it should be awesome after it is completed...
Ryan
Old 06-16-05, 06:08 PM
  #62
THE_CEO
THE_CEO's Avatar
Ryan
some of us as you know cant wait...hehe
CEO
Old 06-16-05, 07:47 PM
  #63
SC400TT
SC400TT's Avatar
CEO
Yeah, I have a few surprises coming out on it that I have not divulged yet... This car should be awesome...
Ryan
Old 06-18-05, 08:08 PM
  #64
SC400TT
SC400TT's Avatar
Originally Posted by 2jznat
but will your wife let you come out or will it be like friday nighr?
She was a good excuse for me to say no... It was to late...
Ryan
Old 08-28-05, 01:01 PM
  #65
JTJerryls400
JTJerryls400's Avatar
I started my sc400 single turbo project. I have garrett gt35r ball bearing turbo.
Jerry
I have almost all bits, waiting for two wastegates tial 38 mm (set at 5 spi) and for big FMIC.
Old 11-09-05, 12:02 PM
  #66
Lextreme
Lextreme's Avatar
Jerry,
I think the GT35R is the best turbo for the 1uzfe street/daily application. I would love to have a ball bearing turbo. I have a GT40 with .68 A/R. Spools at about 1,750 rpm. I am running around with 12.75 psi and would like to increase to 16.5 psi very soon.
Make sure u get an oil restrictor like .035" along with a wastegate spring that will be two psi above your desire boost. For example if you want to run 8 psi, then u should get a 10 psi spring.
Old 11-09-05, 02:04 PM
  #67
JTJerryls400
thanks Lex
I already have that restrictor, it is screw in turbo. I know that bb do not like too much psi oil suply.
So I have restrictor.
about wastegates
I order two tial 38 mm set at about 5 psi.
Each will be for each 4 cylinder banks. I deffinetly do not want boost creep.
I order wgs with small 5 psi spring cause always can rise boost at boost controller.
Most worries is about tranny. I thinhing stock A340 do not last even 7 psi 1UZFE.
valve body from Australia or buy bellhousing adaptor and make it manual 154 from supra...
that is biggest dillema for me now.
Jerry
btw your turbo start making boost at 1750? at with rpms it have 7 psi?
Old 11-16-05, 09:27 AM
  #68
Lextreme
Lextreme's Avatar
7 psi would be around 3-3.5k. I never really record that psi. I plan to run twin GT35R on my SC470TT with .86 A/R. With the Tundra 4.7 Liter and ball bearing, i would expect spooling starts at around 3,500 rpm or so.
Old 04-03-06, 03:58 PM
  #69
VJ RC51
VJ RC51's Avatar
twin GT35R's
Old 11-03-06, 07:42 AM
  #70
sliva001
sliva001's Avatar
Is there a documented failure on a turbo 1UZFE auto trans?
Old 11-04-06, 11:01 AM
  #71
jibbby
Banned - could not follow forum rules
jibbby's Avatar
This is by far the best turbo out there....That's right the almighty electric turbo charger, baby!!!!!!!!!! Intall this rude high powered electric exhaust turbo onto your exhaust system and get prepared to break speed records..
Old 11-04-06, 04:01 PM
  #72
Supra Dr
Moving SC Threads
Supra Dr's Avatar
....... LOL
Old 11-05-06, 11:07 AM
  #73
DoMaMuy
DoMaMuy's Avatar
anyone tried twin GT32-55 turbos? TTurboPimp used it in his GS400TT, SRT-built. Spooled at 2800 rpm. He was running 19 psi and had somewhere around 550rwhp and 654 ftlbs of tq on 20" rims. He also had a 2800 stall TC, and a 3spd Th400 tranny.
kpkim01
SC- 1st Gen (1992-2000)
11-01-09 05:33 PM
brazilian
11-29-05 07:08 AM
VSsc400
13
05-07-02 12:32 PM
TheKevin
09-14-01 08:10 PM
Quick Reply: Best turbo(s) for the SC400? Vote!!!
