2jzgte head on the ge block....
I've already done a search and cant find much info on it. Besides the ignition cahnge over to coil packs and direct ignition what wire harness and which route should i take. could i wire it down like the 2jzgte swap to a turbo ecu and planning to run the map piggy of it. or is thier another route? thanks in advance-pdang
you can do it you just have to run a thicker head gasket to lower compression and use all gte ingnition...wiring....electronics...
friend of mine did it on hi sn/a supra...it wasnt easy but it is a do-able thing....Jeff
WEll just weighing the options I have in front of me. I was just wondering if this is a feasable route to take. I figured the wiring would be my downfall. I realy dont wanna get rid of the ge block or head now that thier are alot of after market options as far as turbo kits goes. Thanks for the heads up guys. Just wondering what cam options are thier. I really dont like the regrind idea from crower. and I want to have aftermaket cams in the head. thanks-pdang
As far as cams go, the majority ARE regrinds...
There are only a very few that use new blanks.
After looking over HKS cams when I put them in my supra motor, and looking over other regrind sets I've had done, I'll probably never waste the extra money on the HKS again. They're nice, don't get me wrong, but not worth the 300% hike over regrinds done by the right place. At least when you're talking street car apps... I can't see going w/ the big guns on a race app. where every little bit counts, but that's a totally different situation.
JDMSoarer5
Performance & Maintenance
08-23-12 09:30 AM
