Motor mounts (already did search)
Old 02-09-04, 12:17 PM
SC400-V8
SC400-V8's Avatar
Originally posted by HotBoy
Lexus OEM motor mounts for the SC400 are $104.00 each 2 sides plus rear or trans mount.
Ok, that sounds resonable. Is there much labor involved with installation, and also should I bother doing this? My car has 70,000 miles, is it about time? I just heard the nice, tight brand new feeling that comes after installation is very enjoyable.
Old 02-10-04, 09:57 PM
HotBoy
HotBoy's Avatar
At 70000 miles I would think your mounts are fine. I am not sure of the labor involved with installing these. I am not sure if you would some how need to slightly lift the engine to do so. I have yet to find anyone that know about this problem on the 400 it is supposedly a common problem but no one really has any experience on it. I have done every search possibble and come up with nothing, maybe if we keep this thread going long enough we will find someone that knows. Or that has a service book and can check the procedure for us.
Old 03-04-04, 03:38 AM
damon
damon's Avatar
Default Part #'s
Please provide some Toyota as well as Lexus Part #'s if possible.
thanks, damon
Old 03-04-04, 09:43 AM
HotBoy
HotBoy's Avatar
Default keep it going
We need to keep this thread going until someone that has done this on a 400. I only know that the lexus ones are $104 each because I called and asked the parts dept. ( they might be $140 if I got the numbers mixed up ) I don't think that there would be any toyota mounts for our cars as or 1uz is not like anything in a regular toyota. Maybe the LS would have similar mounts but they would probably be the same price anyway. It does seem to be a common problem but again I have never heard of anyone that has had it done themselves. The price for the mounts seem reasonable but I am wondering if it is a DIY or maybe th elabor is expensive.
HELP
Old 03-04-04, 09:54 AM
SC400-V8
SC400-V8's Avatar
Check planetsoarer.com for information on this the aussies are VERY resourceful. According to them the engine mounts are 150 each (probably australian?) and the transmission mount is the same. To do this you need to put a jack stand under the engine from what I understand to support its weight and replace each mount one at a time. A shop that could do it for 150-200 would be reasonable enough for me.
Old 03-04-04, 10:15 AM
JPI Racing
JPI Racing's Avatar
To change the motor mounts. You will have raise the engine up from the oil pan. Remember to put a 2x4 under it. Remove the 17mm bolts that hold the mounts to the crossmember. You will need a lift to do this. Very dangerous doing this on a jack.
JPI
Old 03-05-04, 03:39 PM
HotBoy
HotBoy's Avatar
OK here goes
Retail price for these mounts from Lexus are
Right $140.20
Left $104.84
Trans $74.47
There we go I would happly pay $150 for labor so now we have a $ amount to stick on this job.
I will have a lift in the next few weeks so I will do the job and then post the DIY version or what problems are involved.
mikef
SC- 1st Gen (1992-2000)
08-07-14 08:50 AM
Halon
21
11-12-10 05:47 PM
nismo2trd
04-17-07 01:28 PM
jbiel
12-27-05 04:26 PM
DroppedGS
GS - 1st Gen (1993-1997)
12-30-03 12:33 PM
Quick Reply: Motor mounts (already did search)
