GTE swap cooling questions?
I am starting to build up an assortment of parts for this swap, and I am running low on cash very fast. I was wondering If I could use the GE radiator for about a month or 2, or will I run into cooling issues? Also will I need to get an oil cooler or will I be fine with out one?
BTW: The swap is a gte + 6 speed
Your stock radiator will be fine...
The GTE comes w/ an oilcooler. It's is part of the assembly that your filter screws onto and has engine coolant flowing through it...
rockosocko
Performance
05-25-18 05:02 AM
