initial set up for SAFC
Old 02-25-04, 02:08 PM
indypwr
indypwr's Avatar
Default initial set up for SAFC
what wud be the initial set-up for SAFC just toget the car running before
taking it to a dyno tune specialist?
many tks....for any advice.
Old 02-25-04, 02:17 PM
VSsc400
VSsc400's Avatar
0 nothing nothing nothing.
reset everything before you crank the car up.
Old 02-25-04, 02:19 PM
indypwr
indypwr's Avatar
Unhappy
tks bro...but,
r u pertaining to both low and high throtlle?....
Old 02-25-04, 03:48 PM
VSsc400
VSsc400's Avatar
yes
Old 02-25-04, 10:30 PM
TGRich
TGRich's Avatar
If you set everything at 0, your car will run at stock a/f ratio. This will get you to the shop to tune just like it got you around for the other 95,346 miles you've driven.
Old 02-25-04, 10:50 PM
indypwr
indypwr's Avatar
Post
tks guys......so, i shud not even follow the instructions thy have at mkiv.com regarding basic settings.
it tells me not to modify low throttle settings at all but it also indicated to modify high throttle fuel curve
but on the dyno and with air/fuel ratio meter and gauge.
Old 02-26-04, 07:53 AM
NAZTY97
NAZTY97's Avatar
set everything to zeeeeee-ro,... be safer than sorry
Werner05
09-17-17 06:24 AM
6SOARER
06-26-11 06:23 PM
SnShne1jz
17
11-20-07 08:57 PM
blknfury
20
06-27-07 08:13 PM
krazyazzlexus
05-26-02 10:09 PM
Quick Reply: initial set up for SAFC
