Boostlogic kits on a 97 sc300
Hello everyone,
Found your forum while searching the web for turbo informaion for the sc300. I just ordered a Boostlogic turbo kit for my 97 sc300 and I am looking for anyone who has installed one before. I would like to know if what issues you had, how you like it and basic over all performance? Below is a list of parts that I will be installing. This is phase 1 and already planning phase 2, that is after I save up more cash. If you guys see anything else I missed please feel free to pipe in.
3mm head gasket
Greddy, Boost Controllers Profec B Spec II Black
Apexi, Fuel Computers S-AFC II (NEW Version 2) Black Face
550 cc injectors
Boost Logic 321SS Tubular Manifold 1 5/8” Tubing and 1/2” Thick 321SS Flanges
(Turbo’s with a 4” inlet clears the distributor. Manifold fits a turbo up to a T76)
T61 Turbo w/ T4 flange
HKS 40mm Wastegate
3” SS304 Polished Downpipe w/ Flex Joint
3” SS304 Polished Midpipe
SS304 Polished Dump Tube
2 ½” Polished Aluminum IC piping
3” Polished Aluminum Intake Pipe
Boost Logic FMIC Kit
Boost Logic NA-T SS Braided Oil Feed and Return Kit w/ Aeroquip fittings
3” K&N Filter
K&N Breathers
Walbro GSS341 255HP Fuel Pump w/ Install Kit
All necessary clamps and bolts for installation
Cobalt gauges boost, air/fuel, egt
3mm head gasket
550 cc injectors
HKS 40mm Wastegate
3” K&N Filter
K&N Breathers
From talking to Kean at boostlogic this one will have the 4". unless I miss understood him. The kit should arrive in 2 more weeks. Then I will post some photos of the kit.
awesome! sounds like you have some fun ahead of you. I wish they made kits like that for the 4 - if you dont mind me asking what is the general price of a kit like this?
my mistake, the t61 will have a 3".
Go with an AEM and get rid of the Mass Airflow sensor. Other wise you will still have the annoyance of possibly having the engine cut when you hit the gas and then have to brake. If you stay with the MAS setup get the larger newer one that comes in the SupraTT. It has much better flow.
as far as i know, i am the only one with a boostlogic parts on their SC here. I really dont have the full kit from them, I am only using the FMIC pipes, and Manifold. Of those 2 things the quality looks awesome!
From the things mentioned it looks like your on the right track. I dont know what esle you are going to need, but if you do a search I am sure that you will be able to find all the info you can get.
Kevin
Kevin
Kevin
Kevin
Kevin
Kevin
Can you list the parts and the mods that you have done to get 400+. I am still trying to get a good feel for what I will get out. Thanks for the info.
Originally posted by Hermosa
I have a jet coated manifold and downpipe and also a non-coated midpipe.
Kevin
