heat only hot when i press the gas
Old 03-22-04, 09:23 PM
DaizenLex
DaizenLex's Avatar
Default heat only hot when i press the gas
ok its freakkkkinnggggg cold in ny , and my heat seems to work only when i press the gas ac on or off, and it doesnt blow hot air it blows warm air, what gives
Old 03-22-04, 09:24 PM
DaizenLex
DaizenLex's Avatar
WOOOOOOHOOOOOO IM IN POLE POSITION 301 posts just 14890 more to go to be champion!!!!!!!!!!!!!!!!!!
Old 03-23-04, 12:45 AM
PERRYinLA
PERRYinLA's Avatar
4 out of 5 times when this happens, the fix is as simple as topping off the coolant level.
This has been discussed several times on this forum- try it and see!
Old 03-23-04, 07:47 AM
jcm3
jcm3's Avatar
mine did the same thing..low on coolant.
Old 03-23-04, 09:57 AM
siniquezu
siniquezu's Avatar
Worse comes to worse, it could be the heater valve. Check if any coolant is leaking.
Old 03-23-04, 08:44 PM
DaizenLex
DaizenLex's Avatar
check coolant in the radiator when engine is cold? and off?
Old 03-23-04, 10:19 PM
siniquezu
siniquezu's Avatar
You don't wanna check it when it's hot...
Old 03-24-04, 05:32 PM
DaizenLex
DaizenLex's Avatar
um that was a joke guys
Old 03-24-04, 06:15 PM
siniquezu
siniquezu's Avatar
Whew ok. HAHA. I was about to bust a little Did you get it fixed?
Old 03-24-04, 06:28 PM
DaizenLex
DaizenLex's Avatar
you know where the radiator cap is to the bottom left but still on the coolant reseoivar is this other round thing with wires going to it connected to a sensor im assuming ,it was severed , what the hell is it and can that be my problem, it still blowing hot air only when i press the gas my cooling fluid seems up to par
Old 03-24-04, 09:53 PM
PERRYinLA
PERRYinLA's Avatar
That is the coolant level sensor and that surrounding area is prone to leaks from fine cracks that develop. If you're losing small amounts of coolant from that area you would not be the first.
Even if the fluid level looks full, just try adding a little more and see if that helps. I recall one post saying that adding only 2 more oz. of fluid solved the problem.
Old 03-25-04, 10:19 PM
DaizenLex
DaizenLex's Avatar
ill give it a try thanks
peterls
24
09-29-19 02:41 PM
HRoscar
IS F (2008-2014)
21
10-18-18 01:38 PM
99LSprobs
08-22-18 12:37 PM
Cruisin101
02-02-18 01:16 PM
thaimonkee
01-26-07 07:07 PM
Quick Reply: heat only hot when i press the gas
