where can i buy a High Output alternator for my 1995 SC400?
i been searching around for a High Output alternator and im having a hard time finding one for my SC400. Is the SC400 alternator the same for the ES, GS, LS and IS?
any SC400 owners here have a high output alternator in their car? where did you get it and how much?
i am new to the site, what is PHR's contact information. do they have a website?
EDIT: nevermind, i found their site. thanks
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
1tym, if you're located in Southern Cal, anywhere near Los Angeles I know a great place that will rebuild your alternator for under $100. I had them rebuild mine recently and it took them about an hour and 1/2 from start to finish, and they include a 1 year warranty. The place is called "CP Generators" and they're located near downtown LA on the corner of Washington Bl. and Figueroa. #213.746.1060, ask for Eric. Hope this helps.
Originally posted by TGRich
Call around your area to see if any shops can rebuild/rewind it for you- probably be quite a bit cheaper
are there any pros and cons of having the stock alternator rebuilt to have more amps? i believestock amp on the alternator is 100 and im looking for around 150+. i may go this route to save some money, but only if its worth it. i want to do it right the first time.
mikeloc24,
i am from Sacramento, CA 95823. did that place rebuild your alternator to stock specs? can they rebuild a 100 amp alternator and make it 150+ amps?
1tym, I called and spoke to Eric on your behalf. He said he can definitely do the work you want. If your car is a 1992 like mine he can make the amp go up to 170 and the price is $199.99, pretty damn good price IMO. And like I said, they give you a 1 year warranty. All you'd have to do is get the part out of the car and ship it to them, I've been dealing with them for over 5 years and have never had a part fail after having it rebuilt by them. Give it a try if it's worth the effort. Good luck.
wow, thanks for the help mike! i think i will have them do my work.
i probably wont have time to pull the laternator until i get my g35 back from the shop. thanks again
1995, alternator, amperage, amps, atlernator, ca, high, lexus, output, rebuild, rebuilds, sacramento, sc400, specifications, stock, whats
