car wont keep running?
ok so i installed my GTE motor in my SC, and the AEM, with 5 bar map, and IAT(to replace factort MAF)
car starts, idles up, and dies, if i touch the gas at all it dies,
i am trying to figure out what to trouble shoot..... all my interiror works and all so i am 97% sure the wiring is correct.
i have not tried starting it with a stock ecu, since i only have an auto ECU and i have a 5 speed (should i try it anyways?)
basically i want to know what i should check.....
i have not done anything to the map that the AEM came with, maybe i need to change something due to the IAT or the 5 bar map sensor..... maybe someone can send me a map for stock twins running 18 psi, with FMIC, 3inch down and exhaust, and hardpipes.
at least if someone could help me with some pointers on what to check or where to start that would be greatly appreciated
thanks in advance
thanks in advance
