Turbo Kit
Old 04-01-04, 11:50 AM
supralex
supralex's Avatar
Question Turbo Kit
I HAVE A 93 SC300 THAT I WAS GONNA DO A GTEW SWAP ON BUT CHANGED MY MIND DUE TO PARTS NEEDED AND BULL**** MPERFORMANCE SHOPS IN NEW YORK. ANYWAY I'VE BEEN READING THE THREADS ON TURBOING THE GE MOTOR. I ALREADY HAVE A GREDDY T-78 TURBO KIT FOR GTE MOTOR WOULD I BE ABLE TO PUT THIS TURBO KIT ON THE GE MOTOR. WHAT PROBLEMS WOULD I HAVE MOUNTING THIS KIT TO THE GE MOTOR IF ANY. WILL THE GE MOTOR BE ABLE TO HANDLE SUCH A BIG TURBO ALSO. THANKS FOR ANY INFO U GUYS CAN GIVE ME
Old 04-01-04, 11:54 AM
TurboB6
TurboB6's Avatar
No, you can't. GE and GTE heads are different.
Old 04-01-04, 12:10 PM
supralex
supralex's Avatar
Thumbs up
THANKS FOR INFO DO U KNOW OF ANYONE THAT WILL FABRICATE A MANIFOLD TO MAKE IT FIT . CAN THE MOTOR HANDLE A T-78.
Old 04-01-04, 12:18 PM
TurboB6
TurboB6's Avatar
There are several aftermarket manifolds out there. Boostlogic, PHR, Toyomoto, umm DaveH's. I'm sure I'm forgetting some?? I think BL makes an adapter setup for the t78 with their manifold?
mrshabo
mrshabo's Avatar
the motor could if you lower the compression. the tranny on the other hand will blow up. the sc3 also doesn't have lsd so that might also be a problem with that much power. if you need a good installer in nyc, gimme a pm. He works on my car and my friend's supra. He also has a apu supra himself.
Old 04-02-04, 01:50 PM
theman
theman's Avatar
Actually you could make it work... The GTE and GE have different flanges for sure at the head, but it should be very possible to have the flange cut off and replaced with one to fit the GE head. Have the whole thing ceramic coated afterward and you'd probably never be able to tell...
Jay
09-26-16 09:25 AM
breed
SC400 / 300 Classifieds
14
04-18-08 12:05 PM
gdc5ind
18
09-01-07 11:03 AM
prjctSC300
10-09-05 07:48 PM
ObjectZero
SC- 1st Gen (1992-2000)
04-27-05 09:08 PM
Quick Reply: Turbo Kit
