HKS Super Dragger hanging too low?
I have a HKS Super Dragger on my SC300. The problem is that it hangs pretty low and scrapes pretty much anywhere with a decent bump. Anyone else have a problem like this? Are there any other Supra exhausts that fit and have no clearance problems?
the dragger canister is a pretty huge canister so figure in that the clearance isnt going to be the greatest. If you have room on top to play with, you can take it to an exhaust shop and have them modify the hangers to have it hang a little higher.
Yes, this exhaust is for the Supra. However, it isn't the canister that is the problem, but more of the piping. The pipe probably hangs only about 4 inches off the ground. It has been developing a flat spot and I need to find a solution fast or else that flat spot will give way to a giant hole. Hanging it up higher is also a problem since mine's already hang as high as it goes. There is only about an inch between the top of the canister to the car.
Are there any Supra exhausts that don't have their piping hang so low?
schef300
SC- 1st Gen (1992-2000)
03-10-11 03:31 PM
