How loud is the sc300 without mufflers?
Old 04-27-04, 05:58 PM
/Aerostar\
/Aerostar\'s Avatar
Is there anyway to "gut" a stock muffler? That would be sweet if my SC sounded like it did now, but still had mufflers.
PS. Im still workin on that vid clip...Ill get it sometime soon
Old 04-27-04, 06:02 PM
SupraCoup3
SupraCoup3's Avatar
sorry -- refering to the cats -- "factory exhaust (gutted)"
Old 04-29-04, 02:57 PM
SDJZZ31
SDJZZ31's Avatar
I just took the mufflers off my SC3 and it sounds awsome.
Old 04-29-04, 03:56 PM
rscott
rscott's Avatar
You can gut them, but not without opening up the muffler then rewelding it shut. Also, from a performance standpoint, it will likely be not so good. When the gasses hit the muffler with none of the galleys or resonators, the gas will expand to fill the space, then hit the back walls and start bouncing around building up pressure. all the gas-gas turbulence will probably flow a lot worse than the turbulence induced by the muffler as it comes. Within the muffler, the walls inside give the gas direction so that flowback is minimized. Without that direction the gas will flow in random direction.
plus it will probably sound horrible.
lexSCus
15
12-11-07 12:28 AM
100mgbluep
09-30-07 10:21 PM
Dramon
16
04-20-06 06:53 PM
Deuce747
24
07-01-05 03:35 PM
Jmai22
SC- 1st Gen (1992-2000)
08-15-02 12:27 AM
Quick Reply: How loud is the sc300 without mufflers?
