Help! Need a driveshaft for Supra TT auto transmission
Old 04-20-04, 05:56 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Default Help! Need a driveshaft for Supra TT auto transmission
Hi,
I'm doing Supra TT engine and automatic transmission swap. I'm currently stuck because SC300 driveshaft won't fit Supra TT automatic transmission. I need something that would fit into this:
Attached Thumbnails Help!  Need a driveshaft for Supra TT auto transmission-img_0011.jpg
Old 04-20-04, 05:57 PM
DIrEctQL
DIrEctQL's Avatar
Does anyone have a solution for this?
Old 04-20-04, 06:08 PM
racing fan
racing fan's Avatar
the transmission pictured is a 2jzge auto one....
You need a couple of new flanges for the trans and diff(what diff do you have?)
Old 04-20-04, 06:18 PM
DIrEctQL
DIrEctQL's Avatar
I have stock SC300 diff. I have plans to go with TRD auto diff later on. I need something that would interface with my stock diff for now.
Chris
Old 04-20-04, 08:32 PM
soarer 300
soarer 300's Avatar
Put the car on a trailer and take it to a driveline shop. They will have a vast array of couplets that can fit any output shaft. My driveshaft for my TH400 conversion was $70 to modify. I'd use the stocker and have them balance it after they hack off the Lexus part, and weld on the Toyota.
Old 04-20-04, 08:38 PM
DIrEctQL
DIrEctQL's Avatar
Hey kid,
I'm afraid it's not that easy. Don't know any shops around here that would do it. Also, I don't have any other driveshafts than SC300 stock one. Know any such shops?
Chris
Old 04-21-04, 12:16 PM
racing fan
racing fan's Avatar
Is the pictured transmission the one you are using?
Old 04-21-04, 12:32 PM
DIrEctQL
DIrEctQL's Avatar
Yes, that is the Supra TT transmission.
Chris
Old 04-21-04, 12:56 PM
DIrEctQL
DIrEctQL's Avatar
Sorry I goofed. The picture I posted is my old transmission! I will correct it when I get home.
Chris
Old 04-21-04, 05:59 PM
TurboB6
TurboB6's Avatar
If your using the gte auto tranny i still have my 3" phr driveshaft forsale with adapters and hardware.
Jeff
Edit: One of my adapters doesn't fit the 4.27 rear so you'd have to get another made.
Old 04-21-04, 06:39 PM
racing fan
racing fan's Avatar
Chris
Thats waht I've been trying to tell you... Now is your auto tranny a usdm one or a jdm one?
Old 04-21-04, 08:06 PM
William N.
William N.'s Avatar
DIrEctQL,
Do what I did. After a lot of examining and test fitting, I found out that you don't have to get a custom driveshaft made if you are going to use a supra TT automatic in a SC300. Just buy a SC400 driveshaft and a SC400 tranmission output flange. Total amount I spent was $150. (bought the parts from a junkyard)
Good luck
William
Old 04-21-04, 09:17 PM
Lex Luthor
Lex Luthor's Avatar
Originally posted by tt1520
DIrEctQL,
There you go. You can also use the 98-00 SC3 shaft and flange.
Old 04-22-04, 01:19 AM
William N.
William N.'s Avatar
Lex,
I am not sure if he can use the 98-00 SC300 driveshaft because I asked gadget if he could look under both his SC300s and tell me if the transmissions looked different where they meet the driveshaft and he said that they both looked the same.
Old 04-22-04, 06:30 AM
Lex Luthor
Lex Luthor's Avatar
Looked at mine also, looked the same as my SC4, but i'll check again.
Quick Reply: Help! Need a driveshaft for Supra TT auto transmission
