HELP! Will a Supra TT Auto Tanny Bolt up to My Auto GE?
i need to know the answer to this question quick.
will a supra twin turbo automatic tranny bolt up to my 2jzge? what kinda modifications are needed? what extra parts do i need? lsd??? half shafts??? help please!!!!!!!!
It will bolt up but you will need a custom driveshaft and you won't be able to control it with the stock ge ecu. If you use the supra TT automatic, you have to use the gte ecu and the extra wires that connect to the extra sensors that control the TT automatic. Or you can use an AEM to control a supra TT automatic with your GE motor.
Chris
DIrEctQL,
Here's an up-to-date pic of the 2jzgte engine swap in my SC300. I am still waiting on my T bolt clamps, I need to add radiator fluid, and I definitely need to clean the engine bay. I will post plenty of pics once I have time to detail the car. Now its your turn to post a pic of your project.
DIrEctQL,
DIrEctQL,
Chris
I will be upgrading the supra TT automatic transmission and stock torque convertor before I go with a single turbo kit because the tranny will not handle the power from the single. I ceramic coated(not polished) the upper and lower intake manifold w/ TB, exhaust manifold, and stock turbo pipes not just for looks but also for performance. I have scheduled a writeup about the build up with a writer from Sport Compact and Import Tuner that did an article on my last car. The article will explain how I did the swap by using the gte head w/ ge block, TT automatic w/ SC400 driveshaft, how I modified the ge harness, etc.
Originally posted by Boostshakalaka
what a bunch of trouble for the supra auto, i think i'm gonna end up goin with the r154
Chris
BuffNStuff
Performance & Maintenance
19
08-13-14 06:19 PM
