Lsd For Sc300
Lsd For Sc300
i WAS WONDERING IF THE LSD FROM A MK4 SUPRA ('93.5-'98) WILL FIT A '92 SC300? IF NOT WHAT LSD FITS, AND WHICH DO YOU ALL RECOMMEND ?
Im not sure about the supra swap, you should search. However, I do know that TRD Japan makes one for the soarer, ATS makes one for the soarer, and Kaaz makes one for the soarer.
Two tips for you-
1) turn off the caps lock
2)search for this as it has been covered numerous times and there is a plethora of information in regards to your question
Two tips for you-
the auto tt lsd will fit in the stock sc housing for both the 300 and 400. for the 6 speed lsd u need the whole 6 speed rear end including the driver's side axle. check out intellexual.net for more info.
FuMoFFuTT
Performance & Maintenance
04-05-12 12:10 PM
