1jzgte vs the 2jzgte
Old 05-07-04, 10:34 PM
2fsturpast
2fsturpast's Avatar
Default 1jzgte vs the 2jzgte
Alright guys im sure this question has been asked. But here she goes. What is the difference between the 1 jz vs the 2jz? Is there any difference or are they minor? is one easier to put in a 92 sc300 and also is the tranny a must or not? Just let me know guys. thanks
2fsturpast is offline
Old 05-07-04, 11:31 PM
qmtran
qmtran's Avatar
did you use the search? haha...boy r u going to **** the moderators off with this one. 1jz is 2.5 liters where as the 2jz is 3 liters. 2jz has a sinquential twin turbo setup where the 1jz does not. uhhh... i think they both bolt up to the sc's transmission w/ no mods. more parts for 2jz here in the US and easier to get then the 1jz because the 2jz is in the supra and we all know how big the supra tt is.
qmtran is offline
Old 05-08-04, 11:47 AM
2JZ@SPARK
2JZ@SPARK's Avatar
Well the difference in most parts has been stated above the 1jz is a 2.5 liter while the 2jz is a 3.0 the motors are both great fantastic motors.. They both are able to generate 700 ,800 hp levels with Turbo and fuel Upgrades, The 2JZ will produce much more trq over the 1jz.. But it all depends on your budget the 1jz is realativly cheap compare to the 2JZ..
2JZ@SPARK is offline
Old 05-08-04, 12:31 PM
rscott
rscott's Avatar
1jz is relatively cheaper that the 2jz.
at first...
but just wait until stuff breaks. General maintenence will be a pain to deal with. I believe jeff watson at jay marks can get 1jz parts, but not before a relatively long wait.
rscott is offline
Old 05-08-04, 01:29 PM
2fsturpast
2fsturpast's Avatar
do things break a lot on these motors? Are they unreliable. i would think not since they are supra motors right? Or what does the 1jz come out of?
Old 05-08-04, 02:39 PM
qmtran
qmtran's Avatar
toyota engines...if u dont know, then you better go do your homework. pretty much over engineered engines.
qmtran is offline
Old 05-08-04, 03:40 PM
rscott
rscott's Avatar
toyota motors are great, but after so many miles and a certain power level, stuff is bound to break eventually
1jz came out of the soarer, mkiii supra, chaser and a few other cars that never made it to the us
rscott is offline
Old 05-08-04, 05:38 PM
qmtran
qmtran's Avatar
i agree. but heck, everything breaks down.
qmtran is offline
Old 05-08-04, 09:23 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Heheh mods will get you for this one so do a search
The 1JZGTE is a 2.5L motor, twin ceramic turbos (CT12A), intercooled (JZZ30 Soarer and Chasers/MarkII/Cresta etc. use a small (ie. pathetic) SMIC, whilst the JZA70 (MA70) Supra used a bigger (but thin) FMIC), smaller injectors on the 1JZ (380cc from memory?) compared to J-spec 2JZ (440cc) and US-spec 2JZ (550cc). The engines are theoretically similar besides the larger displacement of the 2JZ, plus the different sized turbos and injectors (in a nutshell basically).
Hope that helps.
Jose
BLK13X is offline
Old 05-09-04, 05:59 AM
legendary
legendary's Avatar
As mentioned many times by your peers...the search is your best friend.
Heck, I even made my signature a search button.
Anywho, here is what I came up with on a quick search
Click Here for Search Results
Also, a good resource is www.Intellexual.net
legendary is offline
BigGreen
14
10-01-10 09:52 AM
TLDriver
08-12-09 08:52 PM
nismo2trd
09-06-06 11:39 PM
LeXuSrAcIn
21
07-13-06 10:52 AM
Tommyd1919
13
03-17-05 10:22 PM
Quick Reply: 1jzgte vs the 2jzgte
