Sc4 1uzfe
I'd still do the timing belt though... what's the milage on your SC? On my Soarer I changed my timing belt at 114000kms, but a friend of mine told me belts can last up to about 140000kms, still, better to do it to be safe.
Jose
Jose
I have been told on more than 1 occassion that the timing bels in the 1uz-FE are scheduled every 120K miles !!!! thst is when mine was done and it will be done in a few months at 240K
since you look like you're knew here also while you're in there change the water pump, hydraulic tensioners and everything else associated with the belt. Didn't want to assume anything in case I could save you some headache later on.
flyboyplo
03-31-13 09:14 AM
1uzfe, 1uzfewhat, engine, interference, interferenece, iridium, iuzfe, kiker, l7, maintenance, motor, number, plugs, sc400, year
