shifting when car is stopped?
Old 05-27-04, 06:27 PM
mrshabo
mrshabo's Avatar
Default shifting when car is stopped?
when i use to go from gear to gear when the car was turned off, it was realyl smooth. now it gets stuck sometimes like it doesn't go into gear. what does this mean if anything?
Old 05-27-04, 06:56 PM
Lex Luthor
Lex Luthor's Avatar
Nothing is turning inside the trans when the car is off. When it's running, if something is off..i.e. a damaged synchro...it will be more difficult to get into gear as it's rotating and has to mesh properly.
Old 05-27-04, 08:44 PM
mrshabo
mrshabo's Avatar
so it's def a synchro?
Old 05-28-04, 08:25 AM
Lex Luthor
Lex Luthor's Avatar
That's not what I said, can't diagnose a problem without seeing it, just trying to point you in the right direction....you need to have it looked at, could be a problem with the clutch, TO brng, synchros, sliders, shift fork, etc, etc.
difred
11-29-15 11:21 PM
Stevelocs
IS - 1st Gen (2001-2005)
02-10-11 01:20 PM
Deception
03-24-08 09:26 AM
Lvangundy
Performance
20
08-26-05 08:40 AM
mrshabo
08-02-03 02:21 AM
Quick Reply: shifting when car is stopped?
