Transmission Flush?
the one thing you should know is you need to use the specific oil type made for your transmission from lexus/toyota. if you dont you can run into issues as people have had in the past. i suggest a normal tranny flush from your dealership unless you feel like doing it yourself but always use the fluid suggested by the manufacturer.
If you search for it, you'll find past posts on this topic.
I've read around $200 for a power flush. Replacing 8 Quarts of T-IV ATF isn't cheap.
Don't take it to jiffy lube or something like that, you need genuine Toyota T-IV ATF, not the Dextron crap -- dextron will mess up your tranny.
John
John
Dx3
Be careful mate. Im not sure about the states but here in the UK even the Toyota/Lexus dealers will give you Dextron, saying thats whats recommended. You MUST INSIST that they give you the Toyota Type-4.
When i ordered mine the dealer gave me the Dextron stuff and then refused to take it back when i pointed out the mistake. Its expensive stuff so make sure its the right stuff.
i dont think our auto trannies use type IV fluid do they? Check the dipstick before any assumptions are made. It should say either on the cap or the stick itself. I know the supra TT auto trannies use type IV fluid but when i had my auto NA supra, dextron III was fine.
Just got mine replaced @ the dealership here in Italy, and man what a diference it makes
. I never thought my car could ride so smooth. I have a 92 SC4 and It is just about to reach 60,000 miles so it is time to replace things. So I took it to the dealer and flushed with type IV ( I brought it there myself
) and changed the differential fluid with royal purple synthetic gear oil, And now my girl rides so smooth. Its a must if your car rides rough, not rough but not smooth ;like a Lexus should be. I also had them change the transmission filter while they were at it. I know that its the first time that the fluid has been changed. Cost me 90 euros ($100 dollars) to get it done. Do it
Philly
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
Philly
The auto transmission requires Toyota Type T-IV. If you look at the dipstick of older models it actually says use Type II, but that's Toyota Type T-II, not dexron II. Back then that was the most up to date Toyota ATF at the time. Type T-IV is now the most current ATF. I recently did the flush and it does make a huge difference in the way the car drives and my old fluid wasn't even that bad. I paid $50 to my local mechanic and the fluid cost me $3.78/qt at a local Toyota dealer. Buy it from Toyota and not Lexus. Lexus will charge you twice as much for the same stuff.
the SC300 and N/A MKIV have the same tranny
the SC400 has a different one, almost identical to the MKIV TT just has a different bolt pattern
Originally posted by jeremyp111
Good point. I should've specified that I have a SC400 auto. My bad.
ummmm....just to let you know that all sc4's were auto...so we kinda assumed so.
CEO
I asked my local lexus place if they do a power flush on SC400s and they said no. They also said there's no need to replace the tranny filter. On top of that, they wanted over $50 just to drain and refill!!! I can do that in my driveway!!!!! But, it's been about 35k since my tranny has been serviced, so I need to find an alternative soon. . .
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
CEO
CEO
