wideband o2 location
i know the ideal position would be to put one before the cats.
On the SC400 it is a little tiny bit difficult.
Is it okay to put it aftercat?
I ask because when i went get my car dyno-tuned they put the O2 sniffer on the tailpipe to get the A/F readout....
anyone?
thank you
dennis
anyone?
thank you
dennis
Originally posted by aliga
on the turbo cars, they are installed before any cats, i suggest doing the same.
isnt the cat, burning the unburnt fuel? so your reading may not be accurate.
thats my guess.
thats my guess.
I checked with supraforums and i had mixed answers. Some say close to factory o2 some say doesn't matter if it's in front of the muffler...
What bugs me though is that just about every dyno-tuning facility will use the tailpipe sniffer to tune your car... which leads me to believe that it is okay to have it after the cat.....
what do you think?
dont trust these pros, all they want is your money!
its hard for them to weld in a bung, so they stick in the mufller.
man this just makes things harder... This means i'm going to either drop the headders and add a bung and re-install
or
take the stock cats out, build a pipe and relocate the cat further downstream so i can went the bung in pre-cat....
it just doesn't get any easier.....
I don't know about the "pros" that use a sensor in the tailpipe
My guy replaces one of the stock O2 sensors with a wideband when he tunes!
At any rate, DON't put the wideband sensor behind the cat, you may as well not even use it since the readings will be pretty much useless. Think about it, the cat is cleaning up what the wideband is supposed to be sensing!
The ideal position is 12-18" down from the exhaust port. Any closer and it could burn, any further and it takes too long to warm up (from the AEM literature).
