head swap
Re: head swap
Originally posted by MyScRuNmIa
can you put the vvt-i head from the 99 sc300 wich is the2jz-ge model head onto lets say a 97sc300 would it work an would it be pratical..?
Unless you're going for the all-motor thing, in which case you should sell the 300 and get the 400, bore and stroke it out to 4.9 liters like another member did.
Re: Re: head swap
Originally posted by SupraCoup3
For all that work on a head swap, swaping the GTE head would provide better results
just my .02, Marshall
From what i have heard the GE head has a better design than the GTE head. It flows much better. The only thing that holds it back is the intake manifold. But that can be taken care of by an aftermarket one. I have the GE head on the GTE block with the stock intake manifold in case your wondering.
Kevin
Kevin
Re: Re: Re: head swap
yes, the GTE head doesn't flow as well, but my point was turbo. With the GTE head you'd obviously bring the turbos and the intake manifold.
Yes, it's more work than just buying Dave-H's GTE style intake manifold for the GE head, but he wants info on swapping heads, and I'm just telling him don't try to go all motor.
Re: head swap
yup but im buying actually, all ready bought a silver 97sc300 just waiting for delivery. What about (nos) how do the 2jz-ge motors handale the n20 lets say a 100shot.
it handles 100 shot with no problem.
one other thing gas milage how is the sc300 with that.? my 94sc400 coast $49.00 dolars to fill up how much dose it coast to fill up the
I would also advise you to do some searching because the answers can be found very quickly that way.
as for the gas fill up.
gas price * tank capacity = total cost of fill up.
since ill be spraying a 100shot would msd be useful. one other thing is that my car has tha bfi done to it an nw im trying to figer out what exhacct should i use would get beter performance if i went with a single muffle setup or would itl be the same if i stay dual?
Originally posted by mamurra2
for vvti swap, would be a neat project if you liked wiring, but doubtful you'd see much in the way of power gains unless you had a way of manipulating the vvti..
Sure you will, several ppl are considering doing this swap right now. Not a weekend project, but there are definitely benefits to be had.
